EAGLE User Chat (English) Segmente AUTO command
  • Subscribers 178 subscribers
  • Views 315 views
ameliaamelia
ameliaamelia over 16 years ago
To route my board I am using a .scr with AUTO commands as follow:
auto signal1;
auto signal2;
Doing so, I can apply a "manual priority".
My first wish:
if a signal start from C1 1, goes to C2 4 and ends at C3 2,
1-define a SIGNAL nameA@1  C1 1 C2 4;
2-define a SIGNAL nameA@2  C3 2 C2 4;
if I want two separate action:
use         AUTO nameA@1;
               AUTO nameA@2;
or for a single action:
              AUTO nameA.
My second wish:
in the AUTO command add the possibility to specify the layer number
prefered.
PS:
I started a new project, I am tranlating the Eagle3D (Matthias Weißer
copyright) into 3ds MAX script.
The steps are the same as for POV-RAY using the 3d42.ulp modified to
generate a .ms script.
The advantage is the ability to view the board animated using the mouse; I
am using 3dsMax 2009 and a 3DConnexion mouse.
The work needs a lot of optimizations; as soon as possible a will upload a
video in the projects section.
What do you think about ?
amelia
  • kcadsoft
    kcadsoft over 16 years ago
    auto signal1;
    auto signal2;
    My first wish:
    use         AUTO nameA@1;
                  AUTO nameA@2;
                 AUTO nameA.
    My second wish:
    prefered.
    You may want to take a look at the new "Follow-me" mode of the ROUTE
    command in the latest beta version (see http://www.cadsoft.de/betatest.htm).
    Klaus Schmidinger
    Hofmark 2                               Email:   kls@cadsoft.de
