EAGLE User Chat (English) cant create polygon, getting frustrated
  • Subscribers 187 subscribers
  • Views 394 views
I have a board and make a polygon (trace pour) and connect all the sides. When I click anything else, it disappears. I have created a new board and tried the same thing and it works fine. What is going on?
    autodeskguest over 12 years ago
    - you've drawn the polygon in the one of the routing layers?
    - the respective layer is visible?
    - you've named the polygon appropriately?
    - the polygon is connected to a existing signal per via or trace
    (stub)?
    - ratsnest command?
    if none of that helps come back with a bit more information about what
    exactly you've done.
    Lorenz
