EAGLE User Chat (English) Pad size
  • Subscribers 179 subscribers
  • Views 242 views
Pad size
amerdsp
amerdsp over 16 years ago
What is good practice when you design a new package?  Does the pad size
equal to the median mentioned in the datasheet or the maximum? If a
datasheet states that the pad width is 0.23 +.07 -.05 mm should my pad
be 0.3 mm?
Thank you
A
  • firatkocak
    firatkocak over 16 years ago
    hi,
    while designing a new package, i always be careful about drc violation.
    If a pad width will not result a drc violation then it may be wide
    different from the one specified in a datasheet. So, using the maximum
    values for a pad will be a good choice. Yes, off course i this my opinion.
    Cheers,
    firat
    Amer Abufadel yazm?s,:
    be 0.3 mm?
    Thank you
    A
    If it is a through-hole pad, I'd suggest that you take the maximum value
    and even some 30% margin to have space for solder flow, while soldering.
    If it is a SMD pad, I'd do it using maximum dimensions and increase it
    50% 'outside' the component, to have space to heat the pad for reflowing.
    Cheers,
    Pedro
    be 0.3 mm?
    Thank you
    A
