EAGLE User Chat (English) Chipcon-ti lilbrary question...
  • Subscribers 178 subscribers
  • Views 308 views
I am trying to build a basic RF board using the CC2430 defined in the
chipcon-ti library from the Eagle site.  When I place the symbol on the
schematic all of the power pins are missing.  The part defines two symbols,
one is an IO and RF symbol and the second is the Power pins but the power
pins are not placed on my schematic.
Anyone every used these parts before?  Who build it, the site gives Mc_sho
at gmx.de but that seems to be a strange email address.
Any help would be greatly appreciated.
Ken
  • firatkocak
    firatkocak over 16 years ago
    hi,
    take a look at the symbol drawing in the library. and write down the
    power pin names. If your board schematic has net names for power pins
    then there is nothing to worry about. But if it is not, then simply
    place nets for power pins in your schematic and connect them to the
    proper nets. Namely, if your power pin name is VCC in your library and
    VDD in your schematic, then , either place a net, give a name to VCC and
    connect it to your VDD net, or place a VCC pin from the supply library
    on your schematic and connect it to the VDD net. The same is valid for
    GND ( whatever it is in your library ) though.
    Firat,
    Ken Crismon wrote:
    Ken
    Ken Crismon schrieb:
    Ken
    Just use INVOKE and klick the symbol. In the opening list you can select
    the PWR section of that device.
    Gruß / regards
    Jörn
