EAGLE User Chat (English) anyway to move everything in brd to right?
  • Views 332 views
blewis999
blewis999 over 17 years ago
We have the standard version of Eagle 4.16, and the dimension layer
and we have to put everything to the right of (0,0) up to (100,160).
But we need a component to overhang on the left!?? Is there any way to
move everything on the board layout to the right by (+10mm, +10mm).
Eagle will not allow us to place the parts on the left if they go
minus of (0,0) and the parts do. one is a jack another an SD carrier.
Thank you.
  • firatkocak
    firatkocak over 17 years ago
    I am not so sure but you may use GROUP command. Click the GROUP button,
    and then select the components that will be moved ( selection is just
    like drawing a rectangle ) and later click the right mouse button while
    pointer is on the selected area and finally move the grouped components
      to the right.
    I hope this helps.
    Firat,
    Robert Lewis yazm?s,:
    Thank you.
