EAGLE User Chat (English) When PWR is not the same PWR
  • Subscribers 177 subscribers
  • Views 343 views
I have two instances of an op-amp that must be connected to different
+15VDC power sources.  But when I place them on my schematic, the
board layout shows airwires connecting the PWR pins.  How do I tell
Eagle that these power pins are not in the same net?
Robert Scott
Real-Time Specialties
Ypsilanti, Michigan
    Those opamps have implicit power gates connecting to V+ and V- (IIRC).
    They won't connect to your +15V net if that is named +15V, BTW.
    Simply use INVOKE to make those power gates visible and then connect the
    power pins to whatever nets you like. Approve the ERC warnings you get.
    Tilmann
    On Mon, 02 Mar 2009 18:11:01 +0100, Tilmann Reh <user@domain.invalid>
    This particular op-amp does not have separate power gates.  If I try
    to use INVOKE on it I get a message box saying "Part only has one
    gate."  This op-amp is a single, and the power pins are already
    visible on the schematic, but at present they are not connected to
    anything.  But the airwires are still there in the board.
    Robert Scott
    Ypsilanti, Michigan
    So, here is what I did.  Since the op-amp was already in a custom
    library of mine, I editing the library and changed the direction of
    the power pins from "PWR" to "PAS".  No more complaints.  Of course it
    is now up to me to ensure that the power pins get connected to
    something, because ERC is not going to warn me about it any more.
    Robert Scott
    Ypsilanti, Michigan
    Robert Scott
    Ypsilanti, Michigan
    With your original version on the sch just add a net stub to the power
    pin on each instance and name it the correct net name. You could use a
    supply symbol instead but would have to make one for the +15V_a and one
    for the +15V_b supply.
    Paul R.
