EAGLE User Chat (English) Unconnected pins and net classes
  • Views 358 views
autodeskguest over 12 years ago
I have a opamp circuit with an isolated supply, possible about 100 Volt away
from  normal ground. So all of the opamp circuits nets are on a net class
"pot", with normal design rules with regard to "pot" class nets and more
spacing to default class nets. The opamp however is in a SO8 package with
unconnected 1, 5 and 8. As they have no pins, i can't give them the class
"pot" and they are treated as class "default" and so false spacing
violations are displayed.
Floating copper, e.g. floating smd pads, should be treated as the class it
is checked against.
Uwe Bonnes                bon@elektron.ikp.physik.tu-darmstadt.de
Institut fuer Kernphysik  Schlossgartenstrasse 9  64289 Darmstadt
Tel. 06151 162516 -
Fax. 06151 164321 -
  • dukepro
    dukepro over 12 years ago
    On 03/27/2014 11:02 AM, Uwe Bonnes wrote:
    If they have pins on the schematic, you can draw a net with no other
    connection, then give the nets the appropriate class.
    If you don't have pins on the schematic, your best bet would be to draw
    a wire or polygon on the restrict layer.
    HTH,
        - Chuck
