EAGLE User Chat (English) Rectangular through hole
  • Subscribers 178 subscribers
  • Views 316 views
Hi all,
I need to make aq PCB whit a component which need a rectangular through
hole.
The component is like this http://www.cui.com/pdffiles/PJ-006A.pdf
How can i make the footprint in Eagle PCB?
Thank you
  • mikej_w
    mikej_w over 16 years ago
    Andrea wrote:
    Hi all,
    hole.
    Thank you
    Usually we just use a round hole on parts like this, because it
    sometimes costs more to have a hole routed than drilled. You might ask
    you board manufacturer what the cost implications are. The performance
    should be fine, it just takes a little more solder to fill the hole.
    Mike
