EAGLE User Chat (English) Paste layer - how to create gerber file
  • Subscribers 179 subscribers
  • Views 1465 views
How do you generate a paste layer gerber file?
Thanks!
    On Thu, 05 Mar 2009 11:02:37 -0500, Charles Deling
    Go to CAM Processor from the File menu.  Open whatever CAM job file
    you have been using.  Now save it with a new name (if you don't want
    to change the original CAM job file).  Now as you look at this CAM
    job, you will see tabs across the top that say things like "Component
    Side", "Solder Side", etc.  Each tab represents a different Gerber
    file that will be produced.  The display also shows the file name
    extension that will be used for each Gerber file (.cmp for Component
    Side, for example).  If you don't see a tab labelled "Cream Frame",
    then select any tab and click on "Add".  This will make a duplicate of
    that tab.  Now select that duplicate and make the following changes:
    1. Change the Section name to something like "Cream Frame" or "Solder
    Paste".
    2. Change the file extension to .crc  (for "Cream, component side).
    3. Select layer 31 tCream, and de-select all other layers.
    4. Click on "Description" to document  your changes.
    Finally, save your changes to the new CAM job file, and use this file
    whenever you want to generate Gerbers that have a solder paste layer.
    Robert Scott
    Real-Time Specialties
    Ypsilanti, Michigan
    Paste".
    Robert Scott
    Ypsilanti, Michigan
    thank you!!!
