EAGLE User Chat (English) SMT Equivalent for 1N4004
  • Subscribers 187 subscribers
  • Views 2576 views
Greetings,
Can you tell me a part number(s) for a 1N4004 surface mount equivalent.
I need a small as possible package with the component temperature ratings
@ -65 to 175 C
Thanks very much for help.
    Thanks guys for your input! I erred with the temp spec. It should be -55 to
    +175 C, same as for 1N4004 diode.
    SMB package is too big. If there is a device about half the size of an SMB,
    that would work perfectly.
    The size of a 1/4 W chip resistor would be great!
    A MELF might possibly work but rolling off the pad is not good here.
    "Grzegorz Zalot" <complex@alpha.pl> wrote in message
    news:goulg9$aco$1@cheetah.cadsoft.de...
    Hello Biff !:
    Greetings,
    @ -65 to 175 C
    SM4004 image ! (or SM4007) - Typical MELF package.
    You can search for other diodes because MELF is not easy to solder due to
    quick roll off pad :-(.
    Best temp range have glass packages.
    HTH
    Grzegorz Zalot
    complex ltd.
    office tel/fax : +48 32 2505840
    mobil : +48 501 301515
    Hello Biff !:
    Greetings,
    @ -65 to 175 C
    to quick roll off pad :-(.
    HTH
    Grzegorz Zalot
    complex ltd.
    A common type is the LL4004 (MELF package). I personally prefer SMA
    package for easier handling, look for S1D or the like.
    @ -65 to 175 C
    "As small as possible" depends on your current requirements. And your
    specified temperature range definitely is a problem - the 1N4004 also
    doesn't match it. Besides that, at these temperatures you'll run into
    /many/ problems - with PCB material and all other components, too.
    Tilmann
    Biff schrieb:
    Greetings,
    @ -65 to 175 C
    A simple search like 1N4148 SMD will do that.
    Gruß / regards
    Jörn
