EAGLE User Chat (English) How to do this
  • Replies 8 replies
  • Subscribers 180 subscribers
  • Views 606 views
How to do this
I know how to make a round board but our enginering departement asked me to
produce a disk like the one in this drawing:
http://www.time-tech.eu/Detector_Wheel.pdf
Could someone tell me how to do this?
Harry
    to produce a disk like the one in this drawing:
    Harry
    Hi Harry,
    This is somewhat time consuming but below are the steps that I use for
    creating a circular board with a circular pattern of holes.
    1. Start your circle at the orgin.
    2. Use the circle command to draw your circle: e.g.
    Example
    GRID inch 1;
    CIRCLE (0 0) (1 0);
    generates a circle with a radius of 1 inch and the center at the origin.
    3. Repeat step 2 for your inner circle: e.g.
    Example
    GRID inch 1;
    CIRCLE (0 0) (.75 0);
    generates a circle with a radius of .75 inch and the center at the origin.
    4. Using mark command mark the origin.
    Example
    MARK (0 0)
    5. Now the tricky part. Again using the mark command with polar
    coordinates mark the first smaller circle.
    Example
    MARK (P.75 0)
    6. Use the circle command (Polar coordintates) to draw your circle: e.g.
    Example
    GRID inch 1;
    CIRCLE (P0 0) (.025 P0)
    generates a circle with a radius of .025 inch and the center at the
    origin (relative to mark).
    To place the next hole.
    7.Repeat step 4, Using mark command mark the origin.
    Example
    MARK (0 0)
    8. Repeat step 5, (However use next angle position) Again using the mark
    command with polar coordinates mark the first smaller circle.
    Example
    MARK (P.75 7.5)  Note: The hole rotation will be counter-clockwise.
    9. Repeat step 6, Use the circle command (Polar coordintates) to draw
    your circle: e.g.
    Example
    GRID inch 1;
    10. Repeat steps 4, 5, 6 adding the required angle delta (in your case
    7.5 degrees) to complete the hole pattern.
    I hope this helps. If anyone else has a better way please post.
    Cheers
    Eagle User
    "Harry H. Arends" <info@time-tech.eu> wrote in message
    news:gped9j$21i$1@cheetah.cadsoft.de...
    Harry
    You only need to calculate ONE hole for this. Work at 3, 6, 9, or 12
    o'clock. Lets say you're at 6:00... .
    Draw the circular board outline with the origin as center. Draw your first
    hole at 6:00.
    Copy the hole and place the copy outside the circle, (use a coarse grid if
    you can).
    Group the board, rotate it by 7.5 degrees, then copy the hole copy back to
    the 6:00 position.
    Group the board, rotate...
    (To rotate the PCB: group the entire PCB, click the move icon, RIGHT click
    the group AT THE ORIGIN, type 7.5 in the angle box, ENTER, LEFT click the
    ORIGIN. The board should have rotated 7.5 degrees. You might want to make an
    index mark at some point on the board before you start, that's up to you.
    It would get more complicated if you had to do oddball angles, (maybe,
    360/7?) but you could work with some multiple of the base angle - depending
    on your allowable error.
    Since the total number of holes is divisible by four, you can probably do a
    group copy once you're 1/4 the way done, then once again for the second
    half. Simply eyeball the placement. You will have extra board outlines on
    top of the original that should be removed.
    oww, dizzy -gottaa go
  • tpelectronics
    tpelectronics over 16 years ago
    Can you not make a DXF form your drawing and import to eagle?
    OK you must perhaps set holes manuel.
    Thierry
    "Brett Holden" <brettholden@bellsouth.net> skrev i melding
    news:gpf3m0$imc$1@cheetah.cadsoft.de...
    Harry
    hole at 6:00.
    you can).
    the 6:00 position.
    an index mark at some point on the board before you start, that's up to
    you.
    depending on your allowable error.
    a group copy once you're 1/4 the way done, then once again for the second
  • blewis999
    blewis999 over 16 years ago
    I think you will have to use a script. Create a circle in the
    dimension layer with a wire of 0 and the correct diameter and arc.
    Then for each of the slots specify the exact co-ordinates of the
    squares/slots on a circle inset from the outer edge, then rotate each
    slot in polar co-ordinates
    On Fri, 13 Mar 2009 20:50:14 +0100, "Harry H. Arends"
    Harry
    autodeskguest over 16 years ago in reply to blewis999
    Sorry for the late answer but i have been in hospital for some weeks.
    The problem doenst lies in the holes but the notches in the outer rim.
    Harry
    "Robert Lewis" <robert.lewis@iMnMicroControl.com> schreef in bericht
    news:4fnsr4dcba9hol6fn18oapshl59e79ona0@4ax.com...
    to
    Harry
    autodeskguest over 16 years ago in reply to tpelectronics
    How can i import a dxf drawing into eagle
    "Thierry Pottier" <tp@tpelectronics.no> schreef in bericht
    news:gpihd2$8nv$1@cheetah.cadsoft.de...
    Thierry
    Harry
    first hole at 6:00.
    if you can).
    to the 6:00 position.
    click the group AT THE ORIGIN, type 7.5 in the angle box, ENTER, LEFT
    click the ORIGIN. The board should have rotated 7.5 degrees. You might
    want to make an index mark at some point on the board before you start,
    that's up to you.
  • Richard_H
    Richard_H over 16 years ago in reply to autodeskguest
    Take a look at the Download area, Misc folder.
    There are two or three tools that allow to convert DXF into EAGLE
    script format. Simply search for "dxf" with the search function
    of your browser.
    Richard Hammerl
    autodeskguest over 16 years ago in reply to Richard_H
    On Wed, 20 May 2009, Richard Hammerl wrote to us saying :
    of your browser.
    Bear in mind, though, that the DXF format is a very loose standard and
    the import tools have limitations on which object types they cope with.
    When I tried it on a logo design, the tools all achieved exactly the
    same result - nothing.
    Rob Pearce                       http://www.bdt-home.demon.co.uk
    The contents of this | Windows NT crashed.
    message are purely   | I am the Blue Screen of Death.
    my opinion. Don't    | No one hears your screams.
    believe a word.      |
