EAGLE User Chat (English) Standardizing on drill sizes
  • Subscribers 177 subscribers
  • Views 299 views
When you add parts from many different libraries, you can get many
drill sizes that are quite close together.  If there are too many
drill sizes, the board house may actually charge more to drill the
board.  Usually there is some adjustability in these drill sizes, and
some nearby drill sizes could be combined to reduce the overall number
of drill sizes.  Do any of you make an effort to minimize the number
of drill sizes?  And if so, how do you do it?  The only way I can see
is going back into the libraries and editing the packages, then
updating the layout to use the edited library parts.
Robert Scott
Real-Time Specialties
Ypsilanti, Michigan
    On Mon, 16 Mar 2009 14:12:04 GMT, fake-email@szivuejdl.com (Robert
    I just discovered another possible solution to my question:  The drill
    tolerance parameter in the CAM processor.  Apparently it lets you
    specify a list of drill sizes and a tolerance so that one of the
    listed sizes will be used if it is within the specified tolerance of
    the exact size.
    Robert Scott
    Ypsilanti, Michigan
    fake-email wrote on Mon, 16 March 2009 10:12
    Hello Robert,
    The only way to update the drills of components is to update the library.
    That said, Sunstone Circuits is just releasing a EAGLE tool (that I
    created for them) that will automatically adjust drills for their prototype
    process.  The drill mapping is pretty flexible and you might be able to
    make to work for you.
    If you sign up to labs.sunstone.com you can download the beta version.
    What this tool does is essentially create a local cache of all library
    files and then updates the holes/drills in the footprints as per the drill
    mapping specified.
    NOTE:  To use this it can only work when the board file is open and the
    schematic is NOT.  So copy the PCB design into a blank directory and let
    the tool go on that one copy.
    Cheers,
    James.
    email:  sales2009@eaglecentral.ca
    fax:    888.701.8097
    web:    http://www.eaglecentral.ca
    Online EAGLE Dealer for US and Canada
    EAGLE Design Experts
    EAGLE Enterprise Toolkit
