EAGLE User Chat (English) SOH-28 Library
  • Views 423 views
SOH-28 Library
sgregory@arcadeshop.com
sgregory@arcadeshop.com over 12 years ago
Does anyone have a part library for a SOH-28 package?
Thanks!
- Steven
  • sgregory@arcadeshop.com
    "warrenbrayshaw"  wrote in message news:liunu7$ibh$1@cheetah.cadsoft.de...
    On 20/04/2014 3:38 a.m., Steven Gregory wrote:
    Thanks!
    - Steven
    Yes, you do.
    Check out memory.lbr
    The best way to search for packages you have in your libraries is to
    pretend to add one directly to a board.
    (1) Open the board editor.
    (2) Enable all libraries with 'USE *;' so that all libraries are used
    for the search.
    (3) Click ADD as if to a add a package.
    (4)When the ADD Dialog opens list of libraries is presented, type the
    text you wish to search for into the Search field at the bottom and hit
    SOH-28 is not found but SOH28 or SOH* returns the SOH28-SNAPHAT
    If you have a consistent Schematic / Board pair open you will be
    prevented from adding a package directly onto the board
    HTH
    Warren
    Thanks Warren.  I found it in memory.lib, my earlier search did not find it.
    - Steven
    autodeskguest over 12 years ago
    Thanks!
    - Steven
    Yes, you do.
    for the search.
    HTH
    Warren
