EAGLE User Chat (English) SMD - Solder Mask - Cream Stencil
  • Subscribers 177 subscribers
  • Views 281 views
amerdsp
amerdsp over 16 years ago
Hello all,
   I know that the default solder mask and cream stencil openings are
the same size as the smd pad.  However, in some cases, (such as on page
85 of this datasheet:
http://focus.ti.com/lit/ds/symlink/msp430f2274.pdf) the solder mask is
greater than the pad and the cream stencil is smaller.
Can someone please explain why is it done that way and can the default
eagle settings be used or would it create a problem?
Thank you,
A
    On Sat, 21 Mar 2009 07:04:07 +0100, Amer Abufadel <amer.abufadel@gmail.com> wrote:
    Hello all,
    The solder mask is slightly bigger to make sure it doesn't overlap the pad. This will help to make a contact between the pad on the PCB and the chip lead. The cream stencil is made slightly smaller than the pad so no solder paste will go in between the pads. This helps to prevent short circuits.
    Thank you,
    A
    Using Opera's revolutionary e-mail client: http://www.opera.com/mail/
