EAGLE User Chat (English) vias in pads?
  • Subscribers 187 subscribers
  • Views 286 views
vias in pads?
Does EAGLE support vias in component pads?  These are extremely useful in
minimizing trace lengths in high-frequency designs.  They are also helpful
in tight layouts.  With the advent of filled (Peters) vias in the last
couple of years the concern over solder loss from the component pad into the
via has been eliminated.  I've been unable to place a via in a component pad
and have EAGLE recognize the connection.  Thanks.  Steve
    Yes
    Did you assign the name of the net to which the via should be connected
    to the via? If not -- how should Eagle know that ist should connect them?
    Did you try the alternative method: Route a piece of the track away from
    the pad, change layers (produces a via), route another piece of the
    track, and then move the via into the pad? Why not? Too simple?
    Günther
