EAGLE User Chat (English) BOM
  • Subscribers 177 subscribers
  • Views 284 views
BOM
amerdsp
amerdsp over 16 years ago
Hello all,
   In my designs, I keep a spreadsheet that has all the components that
I used along with the manufacturer's part number and the vendor and the
part number there as well.  I am pretty sure everyone here has something
similar, but what I was wondering is if there is a way I can do this
within Eagle and not go back and forth between Eagle, Firefox and Excel.
Thank you,
A
    I have the same issue, I am interested in if one could give us an idea how
    should we do this professionally.
    Thank you,
    Z.
    "Amer Abufadel" <amer.abufadel@gmail.com> wrote in message
    news:gqc339$r4i$1@cheetah.cadsoft.de...
    Hello all,
      In my designs, I keep a spreadsheet that has all the components that I
    used along with the manufacturer's part number and the vendor and the part
    Thank you,
    A
    autodeskguest over 16 years ago in reply to autodeskguest
    how should we do this professionally.
    Thank you,
    Z.
    Hello all,
      I
    something similar, but what I was wondering is if there is a way I can
    do this within Eagle and not go back and forth between Eagle, Firefox
    and Excel.
    Thank you,
    A
    Here is my 2 cents.  In well constructed professional systems there is
    one control point for design data, the schematic, and one control point
    for the parts in the schematic, the library.  The common disconnect that
    occurs within companies is between the MRP system data and the part
    library.  Companies spend much time and money trying to control this
    connection.  A good example is ORCAD & ORACAL.  Invariably, part database
    control is an endless frustration.
    All part data must be kept in one place and revision controlled (ie.
    SVN).  Eagle does not have an automated method of checking parts in the
    schematic with the library to make sure all is in compliance.  However,
    if the data to control ordering is entered as an attribute in the part
    library, that data will automatically go into the schematic.  Eagle will
    indicate if the user overrides this information (attribute view) but it
    would be a good suggestion to add that to the DRC.  A ULP can be written
    to promote VALUES from an attribute to the VALUE field for the part.  The
    BOM with attributes ULP can be used to output the part data to a CSV so
    it can used to upload to an MRP system.
    Greg
