EAGLE User Chat (English) About changing drillsize and not changing the lib
  • Subscribers 179 subscribers
  • Views 459 views
Hi
I am etching a lot of PCB's my self and using 0,5mm drill for all drillholes
in Eagle. When I drill the hole on the final printboard I use the correct
dillsize according to each component. The reason for this is that it's very
easy to center the dill on the board when I'm using a 0.5mm hole on the
board, otherwise often the dill will be in the edge of the hole and not 100%
in the middel.
The problem is now: I have changed the drillsize on a lot of components in
my database to 0.5mm but if I want the have a PCB made by Olimex I can't
have 0.5mm drillsize on all the holes. At least that will be the problem if
I sent out the brd file directly to Olimex.
But how can I come around this? I will change the drill size in my database
back to the correct size on each component, but I would still like to be
able to make my homemade boards with 0.5mm hole when I do a kitchen table
etching and drilling.
Is it possible to make a gerber or similar file (I dont know anything about
gerber!) that could change the drillsize from the correct size and to my
0.5mm so I can print the board layout on my laserprinter and still preserve
the correct dillsize in Eagle?
Kind regards, Peter Andersen
    On Thu, 9 Apr 2009 10:10:32 +0200, "Peter Andersen"
    <noname@noadress.com> wrote:
    Hi
    in the middel.
    Do you want to change just the drill size?  Or do you want to change
    the pad size too?  If it is only the drill size, then put the correct
    drill sizes in Eagle.  Then run the CAM Processor Job, excellon, which
    will make the drill file, *.drd.  This file is just an ordinary text
    file.  You can edit it with any text editor.  So edit it and simple
    change the drill sizes to 0.5mm, or whatever.  You only need to change
    it for each different drill size, because the drill file has already
    grouped all the holes according to drill size and given each drill
    size a "T" number.  Once you chance the drill size of a given "T"
    number, it will apply to all holes that are grouped in the same "T"
    group.
    Robert Scott
    Real-Time Specialties
    Ypsilanti, Michigan
    Hi
    drillholes in Eagle. When I drill the hole on the final printboard I
    use the correct dillsize according to each component. The reason for
    this is that it's very easy to center the dill on the board when I'm
    using a 0.5mm hole on the board, otherwise often the dill will be in
    the edge of the hole and not 100% in the middel.
    components in my database to 0.5mm but if I want the have a PCB made
    by Olimex I can't have 0.5mm drillsize on all the holes. At least
    that will be the problem if I sent out the brd file directly to
    Olimex.
    database back to the correct size on each component, but I would
    still like to be able to make my homemade boards with 0.5mm hole
    when I do a kitchen table etching and drilling.
    anything about gerber!) that could change the drillsize from the
    preserve the correct dillsize in Eagle?
    group.
    It is only the drill size i want to change. The padsize is fixed.
    But yes, that could work! but what can I then use to print out the excellon
    file with drill file on my laserprinter?
    Peter
    Hi
    Olimex.
    group.
    Peter
    Hello Peter,
    There is a ULP made for this.
    You can design your lib parts with the correct drill diameter and layout
    your board. When you're finished run 'drill-aid.ulp'. It creates a new
    layer (116) with 'pads' overlapping the real pads, having a hole with a
    size that you can select. (ie. 0,5mm). When you print your board select
    this layer as an extra, if you make gerbers (or send your .BRD file)
    just leave it out.
    Richard
    Hello Peter,
    layout your board. When you're finished run 'drill-aid.ulp'. It
    creates a new layer (116) with 'pads' overlapping the real pads,
    having a hole with a size that you can select. (ie. 0,5mm). When you
    print your board select this layer as an extra, if you make gerbers
    (or send your .BRD file) just leave it out.
    Richard
    Thank you SO MUCH for that! I have asked a lot of people about this problem
    and also posted on a eagle NG a couple of times - with no luck at all.
    You've just made my day!! ;.))) great!!
    Thank you so much - I just love that kind of things with Eagle image
    Peter
