EAGLE User Chat (English) How to find library
  • Subscribers 187 subscribers
  • Views 428 views
How to find library
Hello!
I am wondering whether or not there's anyone so happened to came across to
have a library available with the following parts :
ICM7556ISD+-ND - Dual Timer ( SO-14 )
BC847CINTR-ND - NPN BJT ( SOT-23 )
S9014E-04-ND - 1X4 header ( SIP4 - 050 )
SAM1158-02-ND - 2x2 header ( DIP-2X2-050_135 )
I am a new user to this program and not quite sure how to find it? Thanks
for the help!
Wilson
    Wilson Brown schrieb:
    Hello!
    I think I can only find the following
    but I cannot find the rest
    Can somebody help?
    Thanks.
    Wilson
    "Greg" <ash_4@gravitywell.org> wrote in message
    news:gt4qii$all$1@cheetah.cadsoft.de...
    Use the 'Search' function in the 'Add' window...
    And use wildcards, try searching on BC847 and you'll find it...
    Pin headers are in the lib 'pinhead.lbr'...
    "Wilson" <wilson008@msn.com> wrote in message
    news:gt3ig8$bu1$1@cheetah.cadsoft.de...
    Hello!
    to have a library available with the following parts :
    for the help!
    Wilson
    You will dislike this, but NO program has ALL devices available.
    There are new devices every day. So, creating new devices is part of the
    game, that's why all these programs have a library editor.
    You can wait until someone sends you the library, it's also possible
    that you wait forever.
    The time you have waited now you could have used to create the devices
    yourself.
    The easy way is it to cut and paste symbols and packages from existing
    libraries and recombine them to new devices.
    To do that you open a new library and keep it open!
    Check the libraries in the control panel to find suitable devices or
    symbols, rightklick it and "copy to library" (your open library).
    Most packages are available in the "ref-packages.lbr".
    Go to your (open) library, pick a suitable symbol, group and cut it,
    select NEW and give your new symbol a name, then paste the copied symbol
    into your new symbol-sheet. This can be edited now (pins, body). Same
    goes for a package.
    In the device section select NEW and give a name for your new device.
    With ADD you search for your new symbol and place it. Check NEW at the
    bottom right to get a list of packages already in this library. In the
    connct section you will see then a list of pin names from the symbol and
    pad names from the package and you must connect what belongs together.
    That's it in genaral. Save your library and close it.
    Quite all of this is explained in the tutorial page 67 and in the
    manual. Check the eagle doc directory.
    Gruß / regards
    Jörn
    Hello!
    Can somebody help?
    Thanks.
    Wilson
    Hello!
    for the help!
    Wilson
    "Wilson" <wilson008@msn.com> wrote in message news:gt3ig8$bu1$1@cheetah.cadsoft.de...
    Hello!
    I am wondering whether or not there's anyone so happened to came across to have a library available with the following parts :
    I am a new user to this program and not quite sure how to find it? Thanks for the help!
    Wilson
