EAGLE User Chat (English) Split schematics in logical blocks and rout e separately?
  • Replies 15 replies
  • Subscribers 192 subscribers
  • Views 2136 views
I would like to know if Eagle has an option to make logical blocks of some
electronic components and to make connection between them. Then, in PCB
design to route each block separately and after that just route between
blocks.
Is there such option?
    e14 Contributor over 12 years ago in reply to Morosh
    @Tim, thank you. I'll check that out during this week.
    @Morosh, Thank you for your reply. No I am not in hurry, but I have tried
    myself, as you have suggested. Here are some results:
    1) When I change that parameter from 254000 to 8xxxx. I have all elements
    within block with correct size and they have correct size when inserted in
    other the project. So that's it.
    2) But, If I am right, When I change that parameter from 254000 to 8xxxx I
    have problem with drill diameter of pads I have in "mylib" created by
    hierarchical 10, and I have to choose it manually from drop down list - not
    automated like before changes.
    So, don't bother yourself with changing it here, but just make improved
    release of Hierarchical.
    Thank you.
  • Morosh
    Morosh over 12 years ago in reply to e14 Contributor
    On 11/06/2014 13:19, Manu Mjao wrote:
    Finally, I have tried it and find it very interesting - I think it is
    what I was looking for, but I have some questions there.
    I have made a block using instructions from "hierarchical.txt" file.
    When I have started "script make_device" for the first time I had
    multiple errors about having non-existing paths. In that file
    (hierarhical.txt) there is no note (should be!) that script paths should
    be configured per user's PC (in create_device.upl, create_package.upl
    files) - when I have solved that part, I have gone further and had some
    pop-up questions/answers YES, YES, OK ....  and at the end block was
    created. Do some elementary routing there, and I have saved it and now
    ready to import the block to other project.
    For the test, new project is created, I have made schematics with few
    elements and after that I have "add"-ed from my library new element
    which is actually the block I have created. In sch file it looks fine
    and I have clicked on creating brd file. Done ! I have all elements
    ready for routing, BUT regular elements are of normal size, and block
    elements are about 10x or more bigger then regular elements.
    I can't figure this out and find why is 10x or more bigger then regular
    elements!? Help needed !
    Regardless of this problem ( 10x or more scale of block ) I have a
    question - Is it possible to EDIT block within new project's brd file ?
    Let's say, I have shape of the block that I need to change (fine tuning
    job) - to make pcb smaller within new project - to move around elements
    of the block and reroute it again within block , all within new project
    Thank you!
    http://www.element14.com/community/message/116192
    to edit a block, it's like editing any device/symbol/package in a
    library, you open the lib using "open mylib" then you edit the pac or
    sym or dev as usual.
  • Morosh
    On 16/06/2014 16:45, Sousa wrote:
    Regarding previous post:
    Is it necessary to have "the same" working grid while making block with
    grid where I intend to use that block?
    the files are for version 5, there is a need for a small change to let
    them work with v6. I'll do that in the coming days. But if you are in a
    hurry, just change  "254000." to "8128000." in all ulp files and re-try.
    HTH
  • ootbrobo
    ootbrobo over 12 years ago
    Several of my designs use the same elements even the same partial layouts.  The way I handle it is to import those projects into the running project.  When you do this the imported schematic is added as a new page, and the routing of that project remains as it was saved, and appears like a part in itself in your board layout.
    Hi there!
    I have this issue with Hierarchical v1.0 that when I make a block and
    insert it in another schematics and finally make brd file - block elements
    are huge, 10 times bigger.
    Anybody to give a clue what am I missing here ?
    Finally, I have tried it and find it very interesting - I think it is what I was looking for, but I have some questions there.
    I have made a block using instructions from "hierarchical.txt" file. When I have started "script make_device" for the first time I had multiple errors about having non-existing paths. In that file (hierarhical.txt) there is no note (should be!) that script paths should be configured per user's PC (in create_device.upl, create_package.upl files) - when I have solved that part, I have gone further and had some pop-up questions/answers YES, YES, OK ....  and at the end block was created. Do some elementary routing there, and I have saved it and now ready to import the block to other project.
    For the test, new project is created, I have made schematics with few elements and after that I have "add"-ed from my library new element which is actually the block I have created. In sch file it looks fine and I have clicked on creating brd file. Done ! I have all elements ready for routing, BUT regular elements are of normal size, and block elements are about 10x or more bigger then regular elements.
    I can't figure this out and find why is 10x or more bigger then regular elements!? Help needed !
    Regardless of this problem ( 10x or more scale of block ) I have a question - Is it possible to EDIT block within new project's brd file ? Let's say, I have shape of the block that I need to change (fine tuning job) - to make pcb smaller within new project - to move around elements of the block and reroute it again within block , all within new project ?
    Thank you!
    Still don't have time to use it and see , but i shall reply here when I check it.
  • Morosh
    On 06/06/2014 12:53, Sousa wrote:
    I've entered parameter:
    Change Drill 0.000003125
    and it goes smoothly.
    I hope it will not make some problems in future.
    You've right, the drill value must be non-zero.
    I don't remember why I've made it zero, (may be older versions permit it).
    I'll update files as soon as possible.
    does it fulfill your requirements?
