EAGLE User Chat (English) Create a Through-Hole Pad
  • Subscribers 178 subscribers
  • Views 300 views
Greetings and Salutations,
I am trying to create a through-hole pad in the "Pads" layer 17.
I'm using the Rectangle tool to create the pad in layer 17. I am trying to
add a "Hole" and "Drill" to the pad in the respective layers for the hole
and drill.
I can not get the hole to go through the layer. In other words, I cannot see
the background behind the pad where the hole and drill are located.
Is there a tutorial somewhere that shows the steps for creating a
through-hole pad which I can follow that explains all the necessary steps
for creating a through-hole pad?
Thanks in advance for your input.
  • Richard_H
    Richard_H over 16 years ago
    and drill.
    Why you don't use a PAD? This is exactly what you need. You are
    not supposed to draw something in the Pads layer.
    Richard Hammerl
