EAGLE User Chat (English) Pad hole size, please clarify
  • Subscribers 178 subscribers
  • Views 272 views
amerdsp
amerdsp over 16 years ago
Hello all,
   I am confused about the size of the hole in a pad.  What does it
represent?  The drill size of the finished (including plating and all)?
   If it is the drill size, can someone explain how to translate that
from a data sheet?  For example, in this sheet
(http://portal.fciconnect.com/res/en/pdffiles/doc_search/67996.pdf)  the
hole size indicated is 40mil.  What will be the corresponding hole size
in Eagle?
Thanks a bunch.
A
    Amer Abufadel wrote:
    Hello all,
    in Eagle?
    Thanks a bunch.
    A
    It depends on your board house. Some use that as the drill size others
    drill bigger and plate to the hole size.
    Paul R.
    It is common to specifiy the final hole size (after plating). So the
    board house drills bigger. They also take this into account when doing
    their own DRC checks for restrings etc.
    If your board normally uses the drill diameters as they are, explicitly
    tell them to proceed as described above.
    Tilmann
