EAGLE User Chat (English) Script Language
  • Subscribers 179 subscribers
  • Views 493 views
Script Language
I am still trying to get my round board outline in the BRD file.
I produced a DXF file and using one of the Eagle tools i converted it o a
script file.
But the problem is that i would like the center of that outline be on the
center of the board screen.
Therefore it would be helpful if there is some explenaition of the script
language.
Not findeng much help in the included script files.
    a script file.
    the center of the board screen.
    script language.
    The scripting is or can use any of the command line functions with same
    syntax.
    Use the mark and add the relative move commands. The on line help has
    all of the info.
    The on line help describes ULP syntax.
    One other option is to make the board outline a lib device then you can
    move it as one piece.
    Paul R.
    info[8
    wrote on Fri, 22 May 2009 10:13]I am still trying to get my round board
    a
    script file.
    the
    script
    language.
    Hello Harry,
    If you already have a board file with your circuit imported and the only
    issue is that you want it centered, then you can just do that by hand.
    Figure out the offset you have now that you want to remove.  I'll call
    this Xoff and Yoff.  They can be negative or positive.
    First use the command
    set Option.ToggleCtrlForGroupSelectionAndContextMenu 1
    so that your group won't jump when you right click to select the group.
    This will give EAGLE 4 behaviour.  Otherwise, you won't know where you
    are.
    Now turn on all layers and...
    Set grid to be exactly Xoff, group everything, move the group exactly one
    grid in the X direction and zero grids in the y direction.  With the option
    set above, you select your group with the right-click after selecting the
    move command.
    Now repeat for Y direction by setting grid to be exactly Yoff and move one
    grid in y direction.
    Now everything should be centered as you like.  You can return the
    right-click behaviour to the EAGLE 5 default by using the set command and
    setting it to 0.  But I recommend this behaviour.
    NOTE TO CADSOFT: it would be nice if the arrow keys performed movement by
    exactly one grid.  That would make this type of thing much easier.
    Cheers,
    James.
    email:  sales2009@eaglecentral.ca
    fax:    888.701.8097
    web:    http://www.eaglecentral.ca
    Online EAGLE Dealer for US and Canada
    EAGLE Design Experts
    EAGLE Enterprise Toolkit
    "James Morrison" <james@eaglecentral.ca> schreef in bericht
    news:gv6gh3$dn4$1@cheetah.cadsoft.de...
    info[8
    a
    script file.
    the
    script
    language.
    Hello Harry,
    are.
    option
    move command.
    Cheers,
    James.
    fax:    888.701.8097
    Would it be possible to set a new origen at the outline X-Y offset?
