EAGLE User Chat (English) Rotating tekst
  • Subscribers 187 subscribers
  • Views 452 views
Rotating tekst
I would like to place some text with drilled holes where a magnet wil be
placed.
Each hole differs 7,5 degrees around a cirkel and the text must be readably
every setting of the wheel.
How can i rotate text other than 90degrees. As in the imported DXF file the
text stands correct but after importing it stands 0, 90, 180 and 270
degrees.
Harry
    Harry H. Arends wrote:
    And how would i do that using a script placing text along a 120mm cirkel at
    every 7.5 degrees?
    reading-up about polar coordinates in the help might be a start
    Lorenz
    "Joern Paschedag" <jpaschedag@t-online.de> schreef in bericht
    news:gv8ekh$9k7$1@cheetah.cadsoft.de...
    placed.
    readably every setting of the wheel.
    the text stands correct but after importing it stands 0, 90, 180 and 270
    degrees.
    Harry
    If you want just work with the mouse simply click the ROTATE icon, then on
    the top left you'll find ANGLE with a little window right beside it
    (usually showing 90). Just type your angle into that window followed by
    Enter. Then click on the orign of the part you want to rotate.
    Besides you may want to have a look at the spin icons (abc).
    Gruß / regards
    Jörn
    every 7.5 degrees?
    placed.
    degrees.
    Harry
    on the top left you'll find ANGLE with a little window right beside it
    Gruß / regards
    Jörn
