I must hatch a area that has a outer diam of 100mm and a inner diam of 65mm.
I try to do this by hand width arc lines but those bent any way but not the
correct one.
Can I do this with a script?
Harry
correct one.
Harry
Harry H. Arends schrieb:
How do I define a polygon in script is the big question.
See my answer in support.eng.
Please do not post the same issue to both groups, many of us read both.
Please do not "move" a thread from one group to another, unless the
topic really has changed.
Tilmann
For the above geometry, you'd need 17.5 mm anyway - however, a polygon
is always defined by its /outlines/, so the answer is "no".
If you can't use a restriction for the inner circular "hole" since you
are working on non-copper layers, you need to use two C-shaped polygons
that cover (for example) half of your area each. You will have to draw
the inner and outer half-circly as described earlier, and the radial
borders as straight wires.
Something like this:
You'll always have a wire of the polygon width at the border that is
shared by both polygons (the centered vertical line in the above
sketch). Maybe you can play with spacing and width to make it visually
disappear.
You can generate the second polygon as rotated copy of the first, so you
need to draw only one.
Tilmann
As I am trying this to work with the mouse I keep having problems with
changing the wire bend every time correct.
So I rather would do this in a script, working from 9 to now trying again
and again. If a step goes wrong you must start over again and it is
impossible to go one step back whilst defining a polygon.
Harry,
it is not necessary to always quote the full text. See
<http://www.netmeister.org/news/learn2quote2.html> and
<http://www.cadsoft.de/newsguide.htm>.
(Further, you don't need to specify a reply-to address if it's the same
as the sender address anyway.)
65mm.
If have to make that on layer 25. Is it possible to make a polygon that is
19mm width?
disappear.
Tilmann
"Tilmann Reh" <tilmannreh@despammed.com> schreef in bericht
news:gvevt4$3j3$1@cheetah.cadsoft.de...
65mm.
the
correct one.
You can do /almost anything/ with a script.
However, this is not necessary here.
Just start the polygon command with the proper width, then click (or
enter) coordinate (-50 0), choose the right of the two rounded bend
styles, and click/enter (0 50). Proceed to (50 0), you must change the
bend style (use Ctl + right mouse button). Continue for (0 -50) and
finally close the circle at (-50 0).
For the inner clearance, add a circle of width 0 in the corresponding
restrict layer.
Set the polygon property "fill style" to hatch. You can do that during
drawing or afterwards.
(Using the last wire bend style (freehand) is yet faster, but harder to
explain.)
Tilmann
19mm width?
correct one.
restrict layer.
explain.)
Tilmann
