EAGLE User Chat (English) Updating part in a library no longer present
  • Subscribers 177 subscribers
  • Views 221 views
I am working on a board with parts that belong to a library that is not
available.
Is it possible to update the part (Change connections in this case) for a
part without it's library?
Doug
    On Mon, 1 Jun 2009 14:23:47 -0700, "Doug" <doug@midnitesolar.com> wrote:
    available.
    Doug
    Doug;
    Yes, it's possible.  First run "exp-project-lbr.ulp" from the schematic
    window.  This will create libraries for the parts in your project.  The
    library names will be the same as the original libraries.  Then use the
    library editor to change the specific part, and save the library.  Then
    click on library/update and select the library.  Your sch/brd will now have
    the updated part.
    HTH
    -Dave Pollum
    Excellent,
    Thank you,
    Doug
    "Dave P" <vze24h4m@verizon.net> wrote in message
    news:5gl82592qgr8d0ioqkl2akbkhlmh63c1aj@4ax.com...
    available.
    Doug
    Doug;
    have
    the updated part.
    HTH
    -Dave Pollum
