EAGLE User Chat (English) ground pour
  • Subscribers 179 subscribers
  • Views 420 views
ground pour
heedaf
heedaf over 16 years ago
How does one connect the ground pour under a chip with the gnd pin?  I've
got a sot-89 chip and I have the ground pour touching the gnd pin but when I
run the drc it gives me an error saying they are too close?  Any ideas?
DeWayne
    DeWayne
    The polygon name has to match the net name of the ground pin. That is if
    you added the polygon to the board not the lib part.
    Paul R.
  • heedaf
    "Paul Romanyszyn" <pgr@arcelectronicsinc.com> wrote in message
    news:h068f6$7qr$1@cheetah.cadsoft.de...
    when I run the drc it gives me an error saying they are too close?  Any
    ideas?
    DeWayne
    Paul R.
    Thanks for the info.  What if I want to do it in the part?
    ideas?
    DeWayne
    Paul R.
    No clean way in ver 4.xx I have not upgraded to 5.x+ but from what I
    gather in the discussions you can add copper to lib parts but it can't
    be done without DRC errors. You can approve them.
    The best no DRC error way it to put the stop mask in the lib and add the
    polygon to cover that area on the board.
    Paul R.
  • firatkocak
    firatkocak over 16 years ago
    I have made some DPAK library parts with ground pour defined as gnd. In
    fact, ground pour is defined as a pin with name GND like any others. And
    i have no DRC error. If you give me the part number and the link where
    its datasheet is located, then i may make a library part and send you back.
    Firat,
    I've got a sot-89 chip and I have the ground pour touching the gnd
    pin but when I run the drc it gives me an error saying they are too
    close?  Any ideas?
    DeWayne
    if you added the polygon to the board not the lib part.
    Paul R.
    Paul R.
