EAGLE User Chat (English) Draw Poly on other origin not having same result
  • Subscribers 178 subscribers
  • Views 273 views
The first Poly i draw has the correct result but the second who has a other
center does not. Is there a thinking error on just subtracting the new
center value of 75mm
  1. Mark components placement area for mechanical clearance
Change Layer tNames;
Change Pour Hatch;
#Center on 75,75
Poly .2 (75 25) @-50 (75 125) (75 118.3) @+31.7 (75 43.3) (75 25);
Poly .2 (75 25) @+50 (75 125) (75 118.3) @-31.7 (75 43.3) (75 25);
#Center on 0,0
Poly .2 (0 -50) @-50 (0 50) (0 31.7) @+31.7 (0 -31.7) (0 -50);
Poly .2 (0 -50) @+50 (0 50) (0 31.7) @-31.7 (0 -31.7) (0 -50);
  • Richard_H
    Richard_H over 16 years ago
    other center does not. Is there a thinking error on just subtracting the
    new center value of 75mm
    Change Pour Hatch;
    #Center on 75,75
    The coordinate (75 118.3) is wrong, it should be 106.7 instead.
    Poly .2 (75 25) @-50 (75 125) (75 106.7) @+31.7 (75 43.3) (75 25);
    produces exact the same polygon as you did it below with
    center (0 0). The ring has a width of 125 - 106.7 = 18.3
    which is the same as 50 - 31.7.
    HTH
    #Center on 0,0
    Richard Hammerl
