EAGLE User Chat (English) Which library for barrier terminal strips
  • Views 930 views
ross_valusoft
ross_valusoft over 17 years ago
I want to use some barrier strips like this one.
http://www.rockby.com.au/catresults.cfm?stock_no=33572&imageField2.x=72&imageField2.y=6
I have not been able to find it in the libraries, but maybe I am looking
in the wrong place ... any suggestions for what it might be called? I do
not know the maker's name.
Ross McKenzie
Melbourne Australia
  • ross_valusoft
    Paul Romanyszyn wrote:
    Ross McKenzie wrote:
    looking in the wrong place ... any suggestions for what it might be
    called? I do not know the maker's name.
    Ross McKenzie
    Melbourne Australia
    That is a simple part to make. Any lib you find or make your self needs
    to be checked against the data sheet for the part you will be using.
    Once you learn how to do lib parts it is as fast or faster to do it your
    self. Take one of connectors as a guide copy it to your own lib and
    modify it to match the data sheet.
    Paul R.
    Thanks for your reply Paul.
    Yes, I am aware that it is a simple part ... and will probably design my
    own. Perhaps I did not explain myself clearly enough though. What name
    or manufacturer might a similar part be known as in the Eagle libraries.
    I have not been able to find "barrier terminal" anywhere and therefore
    doubt that I am using the correct terminology.
    Ross
    Ross McKenzie
    Melbourne Australia
    Paul R.
