EAGLE User Chat (English) PCB Dynamic View
  • Replies 8 replies
  • Subscribers 178 subscribers
  • Views 601 views
PCB Dynamic View
ameliaamelia
ameliaamelia over 16 years ago
I translated the Eagle3D Matthias Wei�er's (c) work.
I implemented the 3d42.ulp to generate script also for the new engine.
1- POV-Ray is free but creates a single frame; we can do a   simple
sequence of 20-40 frame-sequence.
2- The engine that I use does cost a lot, but I can view the assembly in
the 3D space.
3- My PC is a little toy (Intel:6700 2.66Mhz Ram:4GB Nvidia:8600GT 256k).
4- Download the following MP4
http://rapidshare.com/files/251580632/PCB3DynView.mp4.html
5- here I am to start a following survey:
   a- is the project usable
   b- is the project of interest to you
   c- do you agree to participate to define standard Cadsoft-  Eagle's
packages archive in the form of .lib .pdf .
If at the end I will found positive reasons to continue:
6- The project will be Open-Source type.
7- All new components will be maintained and owned by me and free
distributed using the download from the www..... dedicated site.
Please take in account that this type of work will take a long and heavy
path, but here I am.
Welcome to Cadsoft' guys.
Other news, next post.
amelia
  • ameliaamelia
    N1
    TITLE: TEARDROPS
    I modified (not yet finish) the teardrops2.ulp.
    I added teardrops to the SMD.
    View the following video.
    http://rapidshare.com/files/251624898/PCB3DynView_TearDrops.mp4
    When OK I will post it in the ULP download.
    NEWS:
    1- The graphic engine for PCB3DynView is 3dsMax 2010.
    2- Maxscript language, quite similar to the POV-Ray language.
    3- The rendering time of the single image 1280x1024 on POV-Ray
    is the same for 3dsmax for the complete image(first post) 64 seconds.
    4- After the scene is create, I use the 3Dconnexion mouse (spatial mouse)
    to move the pcb-assembly.
    amelia
    the 3D space.
    amelia
    What 3D Engine do you target?
  • ameliaamelia
    R1
    TITLE: GRAPHIC ENGINE
    1- The graphic engine for PCB3DynView is Autodesk-3dsMax 2010.
    3- I am investigating other engines with a similar script syntax.
    amelia
    I'm very interested in rotating my pcb in real time..
    Have you looked at VRML/X3D viewers for this job? In theory you could make
    an ULP to generate the full vrml/x3d data directly and view it in a standard
    browser..
  • ameliaamelia
    R2
    TITLE: VRML/X3D
    My intentions are to have an archive from which to draw the scripts for
    different viewers, so I put X3d in the todo-list.
    I do not know X3d, as soon as possible I will study the syntax of it.
    amelia
    I think it will be a problem requiring a costly 3D package to do this.
      I could spend that money on other PCB tools that integrate 3d modeling
    for the same price.
    browser..
  • ameliaamelia
    R3
    TITLE: COSTLY 3D package
    1- Yes, you are right, 3dsmax costs, a lot.
    2- I use it because I have it.
    3- Currently there is not a PCB-CAD product that makes high quality
    dynamic rendering (es. Alti... displays silhouettes, not a real images).
    4- A tool/method is chosen according to a level of quality/service on the
    target.
    5- But the main reason of my project is to implement, for the
    CADSOFT-EAGLE, an Open-Source render-archive; my efforts are on this.
    amelia
    I think #3 is a bad assumption.  I am not sure which version of Altium
    Designer you are referring to but the one on my machine is dynamic and
    very high quality with 'real' images.   I can "peel" away layers to see
    blind/buried vias with interal routing,  pan, rotate, zoom all in real
    time.  I can even place and route in "3d".   Just press the "3" key and
    you are in a dynamic 3D mode.  It all happen instantly.    It even does
    real time clearance checking against external 3D models in MCAD packages
    (such as Solidworks).
    Mentor Graphics PADs now has real time 3D capabilities too.
    amelia wrote:
    R3
    target.
    amelia
