EAGLE User Chat (English) How can I import a PC board outline and component placement from a CAD program
  • Replies 8 replies
  • Subscribers 187 subscribers
  • Views 908 views
I'm designing a front panel for a project I'm playing with, the front
panel is pretty tight in terms of tolerance due to restricted space so
the PCB tghat fits to the back of it must be accurately shaped and fitted.
I have a finished CAD model of the front panel and from that I have an
outline for the PC board that I want to import into Eagle.
How can I import a DXF or some other common CAD format into EAGLE to
save me having to redraw the dimensions from another drawing ?
Any help appreciated (I'm using Alibre CAD if it makes any diffference)
Peter
    autodeskguest over 16 years ago in reply to autodeskguest
    peter wrote on Tue, 14 July 2009 10:48
    peter wrote:
    ... actually quite a lot of stuff ...
    Just to close the loop, the dxf2scr.exe  from here ...
    http://www.micromagicsystems.com/#/dxf-converter/4523812840
    tool works great and its free.
    Peter
    .. as long as you can live with roundoff errors to the nearest mil :frown:
    (on average 12.7 microns).
    Unfortunately, I can't.
    Not with parts getting smaller and tolerances getting tighter all the
    time...
    Leo
    autodeskguest over 17 years ago in reply to autodeskguest
    If you have licensed the EAGLE PCB Power Tools 4.x you can also use the
    EAGLE PCB Power Tools Version 5.x because the lifetime update right. The
    version 5 works with EAGLE 4.x as well as EAGLE version 5.x.
    Best Regards
    Falk Stricker
    "Oppie" <Oppie@saynotospam.com> schrieb im Newsbeitrag
    news:h34r3c$q6o$1@cheetah.cadsoft.de...
    Wasn't the Eagle Power tools a third party program that required a paid
    license?
    My predecessor had used version 4 power tools. I believe that the one in
    the miscellaneous download area is one for Eagle 5. I've not tried it yet.
    "Falk Stricker" <falk.stricker@gmx.de> wrote in message
    news:4a558f61$0$18642$4d4ebb8e@businessnews.de.uu.net...
    Hello Peter,
    try the EAGLE PCB Power Tools (downloadarea ==> Misc) for importing DXF
    into EAGLE.
    Best Regards
    Falk
    "peter" <peter.a.wilson@prosysinstruments.nodotcom> schrieb im
    Newsbeitrag news:h31a7r$p51$1@cheetah.cadsoft.de...
    fitted.
    Peter
    peter wrote:
    Oppie wrote:
    "peter" <peter.a.wilson@prosysinstruments.nodotcom> wrote in message
    so the PCB tghat fits to the back of it must be accurately shaped and
    fitted.
    an outline for the PC board that I want to import into Eagle.
    Peter
    I believe that I saw a ULP that allows import of a DXF CAD file into
    Eagle.
    Check in the Eagle download area both under 'ULPs' and
    'Miscellaneous'. There are several utilities. I can't vouch for any of
    them, not having tried them yet. I will have to do something similar
    to your work at one point. By all means, please post your experiences.
    Cheers - Oppie
    As it happens a little more digging and I found what appears to be an
    almost perfect solution...
    Its free and seems to work..
    The only "almost perfect" part is that its a Windows program and I'
    m Linux based... however, it works perfectly under Wine on Ubuntu, so
    its perfect enough for me.
    I have not tried this with my actual task yet, just a couple of DXF's I
    had lying around and the resulting .scr files looked convincing, but I
    have not yet tried it out. (my CAD package is on teh windows partition
    of this machine (it definetely doesn;t work under Wine, or even proper
    virtual machines) and I have not gotten around to moving the files
    around and trying it for real..yet.
    Peter
    I use the dxf2scr from CadSoft's site:
    ftp://ftp.cadsoft.de/eagle/userfiles/misc/dxf2scr.zip
    -Chris
    Christopher Cole, Cole Design and Development, LLC          cole@coledd.com
    Embedded Software Development and Electronic Design       http://coledd.com
    Stow, Ohio, USA                                                800-518-2154
    license?
    My predecessor had used version 4 power tools. I believe that the one in the
    Hello Peter,
    into EAGLE.
    Best Regards
    Falk
    "peter" <peter.a.wilson@prosysinstruments.nodotcom> schrieb im Newsbeitrag
    fitted.
    How can I import a DXF or some other common CAD format into EAGLE to save
    Peter
    Hello Peter,
    try the EAGLE PCB Power Tools (downloadarea ==> Misc) for importing DXF into
    EAGLE.
    Best Regards
    Falk
    panel is pretty tight in terms of tolerance due to restricted space so the
    Peter
    fitted.
    Peter
    I believe that I saw a ULP that allows import of a DXF CAD file into Eagle.
    Check in the Eagle download area both under 'ULPs' and 'Miscellaneous'.
    There are several utilities. I can't vouch for any of them, not having
    tried them yet. I will have to do something similar to your work at one
    Cheers - Oppie
    Peter
    There are several utilities. I can't vouch for any of them, not having tried
    them yet. I will have to do something similar to your work at one point. By
    Cheers - Oppie
