EAGLE User Chat (English) EAGLE for Flex Circuit Design
  • Replies 11 replies
  • Subscribers 178 subscribers
  • Views 4667 views
Hello--
Has anyone used Eagle CAD for flex circuit design?  Is this possible or
even recommended?  If so, then what are some basic design aspects that I
should watch out for?
Nicholas
    "Nicholas Kinar" <n.kinar@usask.ca> wrote in message
    news:4A5437D6.2070904@usask.ca...
    Hello--
    Nicholas
    As with any new project, first find a fab house that can do what you need.
    Then look to see what their input requirements are in terms of line width,
    spacing, layers... pretty much all the usual except a different substrate. I
    have it in mind to make my own specialty membrane keyboards with flex tails
    one of these days.
        Oppie
    Nicholas Kinar wrote on Wed, 08 July 2009 02:08
    Hello--
    Hello Nicholas,
    I'm just releasing a flex cable design today that I designed with EAGLE.
    As Oppie pointed out, the concept is the same from a CAD point of view,
    it's just a different material.
    There are some additional constraints.  The biggest one being that flex
    lines should be perpendicular to traces.  And you'll need a stiffener in
    the areas where IC's and vias are going to be to keep them from cracking.
    Find a few places to get it manufactured and get their design
    suggestions.
    Cheers,
    James.
    email:  james@eaglecentral.ca
    web: http://www.eaglecentral.ca
    Specialising in CadSoft EAGLE
    • Electronic Design Services
    • EAGLE Enterprise Toolkit
    Thanks, Oppie! I need to design a flex circuit so that I can mount the
    SCP1000 barometer outside of the circuit board enclosure box.  Here's a
    link to the datasheet:
    http://www.vti.fi/en/products/pressure-sensors/pressure_sensors/
    Apparently, there are no "ready-made" solutions for this, and the
    company recommends in an app note to use a flex circuit.
    Does anyone know the general cost of producing a flex circuit?  Is it
    more expensive than an "ordinary" PCB?  I think that all I would require
    is a two-layered flex circuit.
    Nicholas
    need. Then look to see what their input requirements are in terms of
    line width, spacing, layers... pretty much all the usual except a
    different substrate. I have it in mind to make my own specialty membrane
    keyboards with flex tails one of these days.
       Oppie
    Thanks, James!
    Ah - good luck with your design!
    suggestions.
    How would you delineate the boundary of the PCB in Eagle?  Would this be
    the same as an "ordinary" PCB?  I am assuming that the flex circuit is
    simply a flexible PCB, so the boundary delineation would be the same.
    Nicholas
    Nicholas Kinar wrote:
    Hello--
    Nicholas
    I am just starting a flex design as well.    In reviewing the input
    requirements I see that some vendors recommend special pad shapes around
    through holes to minimize stress concentrations at the points where the
    trace meets a pad.    Another difference from a hard board is the
    recommendation to add hold-down tabs around thru-hole pads in some
    applications.
    You might want to take at look at a design guide ... I found it helpfull!
    http://www.minco.com/uploadedFiles/Products/Flex_Circuits/Technical_Specifications/FC302.pdf
    Jim
    How many of these are you using? If it's just a low quantity, you could most
    likely get away with manually soldering a #30 awg (.254mm diameter) wire
    directly to the pads. I do this all the time for prototype construction -
    just have to use a fine tip iron and stick to decaf coffee     Oppie
    coffee <grin>.
    The decaf coffee is the essential part image
    I took a look at the test adapter board; thank you for pointing this
    out!  In my application, there is bound to be some vibration, so I am
    kind of leaning toward a flex cable design in lieu of a test carrier
    board.  However, if I can use the test carrier, then all the better!
    Thanks Opie!
    applications.
    Jim
    Great design guide and recommendations; thanks Jim!
    Nicholas
    n.kinar@usask.ca
  • mightyohm
    mightyohm over 16 years ago
    Hello--
    Nicholas
    Hello Nicholas,
    I used Eagle for a flex cable design earlier this year.  It was fairly
    straightforward thanks to some fairly specific design rules from the fab
    house.
    Advanced Circuits has some guidelines for Flex you can use as a starting
    point, regardless of what vendor you ultimately select.
    http://www.4pcb.com/index.php?load=content&page_id=87
    Probably the most important considerations are to avoid sharp bends in
    traces and to route perpendicular to the direction of flex.
    Probably the hardest part of the design was writing the check to the fab
    house - flex is not cheap!  In my case, the cost was more than an order
    of magnitude higher than a traditional PCB run.
    Jeff
  • mightyohm
    This is, of course, incorrect.  What I meant to say was that you need to
    route parallel to the direction of flex.  I suppose this could be
    considered perpendicular to the axis of flex, but in short, the traces
    should go in the same direction as you plan on bending the flex cable.
