EAGLE User Chat (English) PCB layout - both sides of the board -> Can it be use?
  • Views 651 views
I am running the freeware at the moment -> Is it possible for me to use both
side of the board for the PCB layout? If yes, does anyone know how to do it?
Thanks and I am looking forward to hear from you.
With respect,
William Cheng
    autodeskguest over 9 years ago in reply to e14 Contributor
    Rogelio Mangay-ayam Jr. prodded the keyboard with:
    BiTMICRO Services – BiTMICRO's Engineering Services
    (http://bitmicro-services.com/)
    BiTMICRORegistered Networks, Inc., the leader in enterprise flash storage for
    mission-critical computing now offering PCB Design Services.
    At BiTMICRORegistered, we have worked on design that encompass diverse target
    markets and require different implementation strategies. With our
    continuous efforts on researching new PCB design technologies and
    collaboration with Fabrication and Assembly houses, our foundation
    as PCB design bureau strengthened. We are your one stop shop PCB
    solution from design to assembly ready for product testing. Our
    designers are capable of designing complex, multi-layer surface
    mount, high-speed designs and provide a variety of services to our
    clients some of these are: Just submit some basic design
    information, and we'll get you a quote for the work. Let us do the
    board layout, and we'll even place your board order for you. That's
    right, you send us the schematic, board outline, & BOM (with
    component datasheets), we will send you the finished design file and
    finished bare boards. The boards come with the source design file,
    so you and your staff can pick up from where we left off, make any
    necessary adjustments, and reorder, as needed.
    (https://www.element14.com/community/external-link.jspa?url=http%3A%2F%2Fbitmicro-services.com%2F)
    https://www.element14.com/community/message/214982
    I can see where this is going. A straight advert targeting Eagle users
    clients. if you won't play we will take it away. Sneaky.
    Best Regards:
                          Baron.
    e14 Contributor over 9 years ago in reply to autodeskguest
    William Cheng wrote on Sat, 11 July 2009 05:18
    both
    it?
    Hello William,
    I would suggest going through the tutorial that comes with EAGLE (in /doc
    sub-directory of install directory).  It covers this and lots of other
    areas that you're going to need.
    To answer it quickly, use the mirror command.  You can also activate it
    with a middle-click during a move.
    Cheers,
    James.
    email:  james@eaglecentral.ca
    web: http://www.eaglecentral.ca
    Specialising in CadSoft EAGLE
    • Electronic Design Services
    • EAGLE Enterprise Toolkit
