EAGLE User Chat (English) Re: SMD test pad on bottom side with origin on borigins without using mirror command
  • Subscribers 187 subscribers
  • Views 151 views
autodeskguest over 12 years ago
Am 12.08.2014 11:11, schrieb clw:
Is it possible to create a testpad device such that when it is added as
a symbol to the schematic a package is created in the PCB consisting of
a single square test pad on the bottom side with its origin on borigins?
I don't want to have to use the mirror command on the PCB.
I can almost do this but it involves either having the bottom pad origin
in torigins or requiring the mirror command to be used.
http://www.element14.com/community/message/123558
You have to use the MIRROR command which is quite simple. Click the
middle mouse button while the component is attached to the mouse
cursor (e.g. MOVE active) and place it then.
Richard Hammerl
