EAGLE User Chat (English) Automated release script?
  • Views 703 views
I am looking to automate the board release process.
Does the CAM processor have command line options that can be run through a
script? I have a cam job pre-defined so, by itself, this is not a big issue.
We also use the BOM-AM-17.ulp  bill of material processor to make up the
parts list and SMT placement list. Are there any command line options for
this? Are there any general rules for passing data to a ulp by command line?
tia - Oppie
  • dukepro
    dukepro over 16 years ago in reply to Richard_H
    On 01/21/2010 04:46 AM, Richard Hammerl wrote:
    James Morrison schrieb:
    Richard Hammerl wrote on Tue, 21 July 2009 05:21
    through
    a script? I have a cam job pre-defined so, by itself, this is not a
    big
    issue.
    James,
    no you can't load a CAM job this way.
    You have to write a script/batch file that generates one Gebrer file
    after the other...
    eagle -X -dgerber_rs274x -ogeberfile.cmp  test.brd  1 17 18
    eagle -X -dgerber_rs274x -ogeberfile.sol  test.brd 16 17 18
    eagle -X -dgerber_rs274x -ogeberfile.plc  test.brd 20 21 25
    and so on....
    You could combine this with a batch script that parses the .cam file to
    produce a temporary shell script that then gets executed.
    Maybe adding an "execute ULP" would be a good suggestion for a command
    line option.  I can see where the release process might bump a global
    attribute "REVISION".  There's no way to do this from the command line.
    Of course, when XML .sch and .brd files are available, it'd be easy to
    parse that to pull pertinent data out of it.
    Enjoy,
        - Chuck
  • Richard_H
    Richard_H over 16 years ago in reply to autodeskguest
    through
    big
    issue.
    You can start eagle with command line options and make, for example,
    a batch file for the CAM processor output.
    See appendix, chapter 10.3, in the EAGLE manual.
    Richard, is there a way to tell EAGLE to run a CAM job from the command
    line?  I can't see one.  I already have a CAM job with the funky %P
    placeholder (which really helps) so I'd rather have to not go and write a
    bash script or something for every layer to accomplish the same thing.
    Ideally, I'd like to see
    eagle -CAM 6l-2s-gerbers.cam design.brd
    and that would run the CAM processor, load the CAM configuration
    "6l-2s-gerbers.cam" on the design "design.brd".
    James,
    after the other...
    and so on....
    Richard Hammerl
    autodeskguest over 16 years ago in reply to autodeskguest
    It would help a lot if the CAM processor had some neat extra features:
    -Add a section load a specific project, brd or sch
    -Add a section to run a specific ULP (also needs access to sch) or
    executable
    -Add a section to print to pdf (also needs access to sch)
    This way, i think you could fully automate the release process.
    autodeskguest over 16 years ago in reply to Richard_H
    through
    big
    issue.
    Cheers,
    James.
    email:  james@eaglecentral.ca
    web: http://www.eaglecentral.ca
    Specialising in CadSoft EAGLE
    • Electronic Design Services
    • EAGLE Enterprise Toolkit
  • Richard_H
    Richard_H over 17 years ago
    a script? I have a cam job pre-defined so, by itself, this is not a big
    issue.
    for this? Are there any general rules for passing data to a ulp by
    command line?
    tia - Oppie
    Richard Hammerl
