EAGLE User Chat (English) 20 years of EAGLE 20?
  • Subscribers 179 subscribers
  • Views 414 views
Hi all,
This line on the website grabbed my interest:
The EAGLE Layout Editor is copyright protected software,
Copyright1988-2009 CadSoft Computer GmbH, all rights reserved worldwide.
So, does EAGLE really exist for 20 years already? I only got to use the
software from about version 3.5 I think, so I really don't know anything
about the early versions. What were they like? Was there already a
website? I tried using the wayback-machine website, but that only goes
back to 1996. Are there any screenshots of those early versions? I'm just
really curious about this and maybe if I'm lucky one of the devs could
tell me something about those early ears if they have the time?
Thanks, Wouter
Using Opera's revolutionary e-mail client: http://www.opera.com/mail/
    Yes, it's that "old". I jumped in 1990, IIRC, at V1.2. I was employed at
    the local university then, and saw someone using it at a trade fair. Its
    usage was much more efficient than the CAD system we had 'til then, and
    I managed to get a license for the institute I was working for.
    The first versions were plain DOS versions, without schematic capture. I
    am not sure when the autorouter was added, since I never really used it.
    However, I remember doing some speed comparisons between a 486DX33 and a
    486DX2-66 some times, for which I (mis-)used the autorouter. That must
    have been in the early 90s, so the autorouter is also fairly "old".
    I don't know of a website, since noone had internet connections and
    browsers these days. Remember that the internet and all those website
    stuff is pretty young, in fact it started not before the mid 90s for
    common people.
    We got the software on diskettes, first 5.25" DD(?) and later 3.5" HD. I
    think I still have some of those old installation disks. image Early
    versions used a hardware dongle at the parallel port. Sometimes boring
    since it wasn't as transparent as promised, and most PCs had only one
    parallel port...
    I don't have any screenshots. Note that without GUI there were no tools
    to take screenshots, either. Each application needed to bring their SVGA
    drivers with them. Luckily, several SVGA cards were pretty common then
    (Tseng ET3000, ET4000 based), so that worked OK for most. Most
    applications still used plain text screens. Today, you could try to run
    those old versions in a VM with standard VGA or XGA screen emulation and
    then take screenshots... However, due to the dongle I don't know if this
    would work.
    Interesting however that you still can process EAGLE files from these
    older versions today (after upgrading them to V2.6 by command line tool).
    Tilmann
    common people.
    parallel port...
    would work.
    Tilmann
    I jumped into eagle 1991 with ver. 2, and yes it had an autorouter.
    Checking my old file folder I even found the three 5.25" installation
    diskettes ;-).
    Next time I clean up my pc, and if I don't forget it, I'll hook up a 5"
    drive to it and try if those disks are still readable.
    Since you mentioned the dongle - I remember having a stack of 4 dongles
    plus the printer on the parallel port and used a wire to take off some
    weight from that construction. I still wonder how that could work, but
    everyone used a dongle in those days.
    Gruß / regards
    Joern
  • kcadsoft
    kcadsoft over 16 years ago
    On 07/31/09 14:43, Wouter Mense wrote:
    Hi all,
    Yes, it does image
    ...Was there already a
    back to 1996.
    Our web presence started in summer of 1995.
    Klaus Schmidinger
    Hofmark 2                               Email:   kls@cadsoft.de
    Wouter Mense <woutermense@gmail.com> wrote:
    Hi all,
    Who else remembers the cupon action, promising a some manual (or something
    else) that could be printed out only on cracked eagle versions.
    A lot of work for the legal department, as some student additionally
    installed a cracked version on the PC with the aquired legal Eagle
    version...
    Uwe Bonnes                bon@elektron.ikp.physik.tu-darmstadt.de
    Institut fuer Kernphysik  Schlossgartenstrasse 9  64289 Darmstadt
    Tel. 06151 162516 -
    Fax. 06151 164321 -
    Hi all,
    my first Eagle design is dated 1990. Also using Tseng ET3000,
    networking via COM port (Kirschbaum Link).
    1990 was the age of mailboxes, we didn't even use ISDN. I still have
    great analog modems, a US Robotics Courier and a Zyxel 14400 modem
    (well, I also have a 300bps acoustic coupler). Our E-Mail
    communication started much later using a FIDO Gateway.
    Me. Bad PR and a big mistake, IMNSHO.
    version...
    ...among other reasons because the dongle was annoying.
    One can still run into trouble by careless use of third party
    libraries containing "bad" signatures. It can render the whole design
    useless after an update to a new Eagle version.
    The bad thing is that it likely affects the legitimate Eagle user
    including a downloaded library part, but not people using the cracked
    Eagle version - they likely know how to "sanitize" the library and
    even a whole design.
    IOW: downloaded .lbr (.sch, *.brd) can be "toxic"!
    Oliver
