EAGLE User Chat (English) How to export Part Name, X and Y?
  • Subscribers 178 subscribers
  • Views 538 views
I am looking through the ulp's and cam area and don't see anything obvious
to export a part name, x and y centroid list.
Any suggestions welcome.
    On 8/1/09 5:11 PM, in article C69A27D9.25A%whois_jon_galt@yahoo.com, "JGalt"
    Found it  mountsmd.ulp
    autodeskguest over 16 years ago in reply to autodeskguest
    On 8/1/09 5:17 PM, in article C69A292A.388%whois_jon_galt@yahoo.com, "JGalt"
    Ahhhh  only metric available for export XY?  Any english version?
    Take a look at the ulp in a text editor.
           printf("%s %5.2f %5.2f %3.0f %s %s\n",
              E.name, u2mm((xmin + xmax)/2), u2mm((ymin + ymax)/2),
              E.angle, E.value, E.package.name);
    see the u2mm command and find the one u2?? for the units you need. That
    info should be in the help about ulp's
    Paul R.
    You should be able to find where to change it.
    Paul R.
    Paul Romanyszyn wrote:
    "JGalt"
    "JGalt"
    obvious
    Paul R.
    Paul R.
    See mount.ulp it uses u2mil
    Paul R.
    Thanks Paul   that is the right track.  I adjust u2mm to be u2inch and got
    out the inch version.  However, I wanted to use 4 decimals if possible and
    using u4inch produces an error.  Is there a method to change this to 4
    decimals?
    On 8/1/09 6:58 PM, in article h52rrh$acm$1@cheetah.cadsoft.de, "Paul
    Paul R.
    Paul R.
    OK!  I see that the format is listed as 5.2  so I made it 5.4 and go 4
    decimals.
    Thanks!
    On 8/1/09 7:39 PM, in article C69A4A8F.5E3%whois_jon_galt@yahoo.com, "JGalt"
    decimals?
    "JGalt"
    Paul R.
    Paul R.
