EAGLE User Chat (English) Size of drills, pads and via's
  • Subscribers 179 subscribers
  • Views 405 views
I am a bit annoyed with the many different drill sizes eagle uses in the
libs and the very small pads/annular rings on the component layout. I think
they are generally too small.
I am thinking about changing the drill size and the pad size on the
components I use to standard drill size 0,7mm, 0,9mm, 1,0mm, 1,1mm etc., and
then change the padsize to something like padsize=3*dill size. I think that
rule is generally working ok.
But......
I have never had any PCB sent to PCB houses like Olimex etc. but I have a
few projects I would like to send out.
Are there any problems with this idea about changing drill and padsize that
could be a problem if I'm sending a design to a PCB house like Olimex? Are
there standard sizes for PADS's and vias that I have to use or any other
limitations? (I don't know how they make them)
Peter
    On Sat, 22 Aug 2009, PA wrote to us saying :
    They're generally too small for home etching, which is why there's a ULP
    to dump bigger pads on all holes. However, if you're sending the design
    to a professional board house, the library default sizes are generally
    the right ones for a properly built PCB.
    Rob Pearce                       http://www.bdt-home.demon.co.uk
    The contents of this | Windows NT crashed.
    message are purely   | I am the Blue Screen of Death.
    my opinion. Don't    | No one hears your screams.
    believe a word.      |
    "Robert Pearce" <news@bdt-home.demon.co.uk> wrote in message
    news:b5a4A3CzUEkKFwyk@daniel.huneausware.local...
    think
    to dump bigger pads on all holes. However, if you're sending the design to
    a professional board house, the library default sizes are generally the
    But could there be a problem if I change the padsize?
    Olimex has specific standard drills that I like to use but Eagle has a lot
    of "strange" drillsizes in the libs, thats why I would like to change them
    to a standard size for the PCB house.
    I know the ULP, but in many cases I would like to change the shape also (fx.
    octo to round) so I change the drill, shape and size.
    Peter
