EAGLE User Chat (English) clearance between SMD parts?
  • Subscribers 187 subscribers
  • Views 575 views
How much clearance do I need between SMD parts such a 0603 and 0403
parts.  I've heard in passing, that if pads for one SMD part are too
close to the pads for an adjacent SMD part, that the pick-n-place
matching might place them too close, resulting in the parts being
shorted.  Are there rules of thumb on this, or something on-line that
address this issue?
-Dave Pollum
    Dave Pollum wrote:
    On Fri, 28 Aug 2009 17:54:30 -0400, Dave Pollum <vze24h5m@verizon.net>
    address this issue?
    -Dave Pollum
    Sorry, that should have been "pick-and-place machine".
    -Dave Pollum
    As with all questions related to PCB production it is best to ask the
    assembly house(s). The local one I was going to use required 0 clearance
    between parts because the they used vacuum pickup on parts and the head
    was smaller then the part. So how much error does the pick and place
    machine have and how much part size variations would you have.
    The pad shape and clearances are somewhat affected by the soldering
    method and in most if not all cases will be bigger then the package so
    the pad to pad clearance should be all you need to worry about. If you
    need to do hand solder or rework/repairs larger pads and adding more
    clearance between part helps when removing one part.
    Paul R.
    address this issue?
    -Dave Pollum
    -Dave Pollum
