EAGLE User Chat (English) Viewing gerber files
  • Subscribers 187 subscribers
  • Views 2389 views
JimD1
JimD1 over 16 years ago
Can anyone tell me the method of how to view gerber files in Viewmate or
GC-Prevue.  Doing a straight import of the RS274X gerbers into both software
packages produces strange results, like mirroring of middle layer of 4 layer
PCB.
Best regards,
Jim
    "Jim D" <j.doyle@optosci.com> wrote in message
    news:h98874$lje$1@cheetah.cadsoft.de...
    software packages produces strange results, like mirroring of middle layer
    of 4 layer PCB.
    For all you out there that doesnt already know, I recommend trying Macaos
    for gerber viewing (free after registration).
    http://macaos.com
    Tilmann Reh wrote:
    Jim Littlefield schrieb:
    Gerbers generated by the CAM processor will import fine into Viewmate.
    They also import fine to GC-prevue.
    BTW, there were several reports about Viewmate incorrectly displaying
    something - with GC working correct on the same files.
    What you can do in GC-Preview is highlight all the files you want to
    import via CTRL-LeftClick. Once imported and the colors are adapted to
    something less gross than pink and chartrouse store a *.gwk file in the
    same Gerber directory. That allows fast opening when you quickly want to
    look something up.
    I just wish any of the Gerber viewers had a transparent option so I
    don't have to constantly hide/unhide layers. That can give carpal tunnel
    syndrome. I think it was gerbv under Linux that does this but in
    transparent mode it is very sluggish.
    Regards, Joerg
    Tilmann
    Jim D wrote:
    PCB.
    Best regards,
    Jim
         Its more convenient if you move the gerbers to a separate directory
    and then do an import->directory in Viewmate.   This will save you from
    importing the individual layer files one at a time.
    jiml
    Doug wrote:
    You may want to verify that you do not have "Mirror" checked in the cam
    processor. It can be set for each tab.
    Yep, I never had GC-Preview mirror layers on its own.
    Regards, Joerg
    of 4 layer PCB.
    Best regards,
    Jim
