EAGLE User Chat (English) Correctly displayed text on bottom surface
  • Subscribers 179 subscribers
  • Views 1684 views
To correctly display text on the bottom surface, what should the
settings be?
Layer= 26bNames?
Text mirrored (and thus shows up as mirrored in the board view)?
    you can put the text on any layer you want, what makes it appear on the
    bottom of the board is whether that layer is included in the bottom
    silkscreen gerber file. make sure you use vector font or you will get a
    nasty surprise when the board arrives ( been there ).
    the text should be mirrored when viewed in the board editor which is a
    top view. if the text is attached to a package, it will mirror
    automatically when you mirror the package to place it on the bottom.
    Gary,
    Thanks for the feedback.  Have already had two surprises with missing
    (wrong layer) and mirrored (correct layer, but not mirrored on board view)..
    I am not familiar with what you mean by package??
    Ken
    Former Member over 16 years ago
    see the attached pictures & use online-help, tutorial & manual
    r
    the bottom of the board is whether that layer is included in the
    bottom silkscreen gerber file. make sure you use vector font or you
    will get a nasty surprise when the board arrives ( been there ).
    Gary,
    view)..
    Ken
    Gary,
    Never mind the package question. Read your comments a little to fast and
    before that first cup of coffee..  Yes, I know what you meant.
    Having been through two text errors, I just need to be more careful.
    One unexpected effect-- and that may be the nasty surprise you referred
    to-- is although the mirrored text is displayed inside the board with
    the proportional font that was used, part of the text is cut off as it
    is positioned too close to the physical board edge.
    Ken
    proportional fonts can not be drawn onto the finished boards, they will
    be converted to vector fonts, with unpredictable sizes and locations. do
    not use proportional fonts on your board.
    I sense you may be new at this. is your text attached to a component's
    package ( such as name or value) or just written onto the bottom
    silkscreen as additional information?
