EAGLE User Chat (English) Res network with multiple values
  • Subscribers 177 subscribers
  • Views 383 views
BrotherTheo
BrotherTheo over 16 years ago
I need to make a library part for a resistor network with 4 individual
resistors with different values. How do I do this? When I try it always
makes all parts have the same value.
Thanks!
--Tim Ressel
    Tim Ressel wrote on Thu, 01 October 2009 15:43
    I've never seen a network resistor with different values per element.
    In any case, the value is a per device setting, not per gate.  So what
    you'll need to do is to make a monolithic part (i.e. not 4 gates of 2 pins
    but 1 gate of 8 pins, if it's a 4 element array).  You could put the value
    per element in text then if you'd like to display that.  The value for the
    device can then be either the p/n or the various values of the 4 elements
    (e.g. 10K, 1K, 10K, 1K).
    At least that is what I would do.
    James.
    email:  james@eaglecentral.ca
    web: http://www.eaglecentral.ca
    Specialising in CadSoft EAGLE
    • Electronic Design Services
    • EAGLE Enterprise Toolkit
    you could just hide the "value" generated by EAGLE. and add some other
    values to each gate symbol for the resistor value. I suppose the parts
    true value will be a part number for your BOM anyway.
