EAGLE User Chat (English) Copy symbol from schematic to library
  • Subscribers 179 subscribers
  • Views 283 views
Hello.
I found the schematic on the internet and I wonder if it is possible to
copy the symbol, used in it, to the library.
Regards
Boris
    Boris wrote:
    Hello.
    Regards
    Boris
    There are many export ulp's that will regenerate the lib's. Be careful
    as if you use a part made with a cracked version of Eagle when you
    update Eagle it may detect that and render that schematic-project
    unusable. I think if the ULP generates a scr it won't be a problem.
    See bulk change of reference library in support on Oct 10.
    Paul R.
