EAGLE User Chat (English) Eagle ULP export to CNC GCode Kickstarter
  • Subscribers 187 subscribers
  • Views 432 views
  • eagle
  • pcb
  • cnc
  • gcode
Hello fellow Eagle fans,
I've been working on a ULP for Eagle that will export a board to GCode so it can be isolation routed on home CNC machines.  I am running into a conflict with my current version of Eagle and I am running a Kickstarter to upgrade my license in return for access to the ULP script.  The ULP allows for double sided boards as well as cutting of the "Milling" layer, allowing for non-square shapes, tabs, etc.  I thought the others in this community would be interested in this ULP and would like to help with the upgrade.
https://www.kickstarter.com/projects/1521633130/eagle-pcb-update-for-cnc-double-sided-pcbs
Drew
