EAGLE User Chat (English) Autoroute angles
  • Subscribers 179 subscribers
  • Views 1008 views
Autoroute angles
I am using the autorouter in 5.6.0 and do not seem to be able to prevent
traces going at an angle.
I have set and set preferred directions and set the costs for diagonal step
and ortho step very high and this does not help.
What setting do I need to update to have traces go vertical or horizontal
only?
Doing the last few traces manually is difficult with angular traces present.
Doug
    just guessing...but there is a cost "NonPref" that sounds like it might
    be what you need.
  • Richard_H
    Richard_H over 16 years ago
    Doug schrieb:
    only?
    Doug
    There is no fixed setting that forbids diagonal steps, but try
    to set
    cf ExtdStep = 99
    mn ExtdStep = 0
    cf OrthStep = 1
    cf DiagStep = 5....10
    HTH
    Richard Hammerl
  • Richard_H
    to set
    cf ExtdStep = 99
    mn ExtdStep = 0
    cf OrthStep = 1
    HTH
    And don't forget to set this in the Optimize passes as well.
    Richard Hammerl
    Former Member over 16 years ago
    Hi Doug,
    Just a note, I'm not  trying to tell you how to build a specific board but
    angles make a better overall board, there are less stresses on tracks. I cut
    most of my corners with angles.
    Rob
    "Richard Hammerl" <ric@cadsoft.de> wrote in message
    news:hbp7gn$a9v$1@cheetah.cadsoft.de...
    to set
    cf ExtdStep = 99
    mn ExtdStep = 0
    cf OrthStep = 1
    HTH
    Richard Hammerl
    Richard,
    I have set it up as suggested.
    It will be about a day until it is done, but I should be able to see soon if
    it is helping.
    Doug
    to set
    cf ExtdStep = 99
    mn ExtdStep = 0
    cf OrthStep = 1
    HTH
    Richard Hammerl
    Richard,
    Thank you,
    That worked well.
    Doug
    "Rob" <euclid@delhitel.net> wrote in message
    news:hbpodv$ioh$1@cheetah.cadsoft.de...
    Hi Doug,
    cut most of my corners with angles.
    Rob
    to set
    cf ExtdStep = 99
    mn ExtdStep = 0
    cf OrthStep = 1
    HTH
    Richard Hammerl
