EAGLE User Chat (English) eagle2freerouterV6-4 error - help please
  • Views 550 views
  • freerouting
ronsegal
ronsegal over 11 years ago
Hi folks
When I run the ulp on an in-progress, 2 layer board design (Eagle 6.6) it returns an error:
C:/Eagle_Libraries/eagle2freerouterV6-4.ulp(275):
Invalid argument in call to 'asin(1.244)'
Any ideas on what might cause this would be appreciated.
Does the board need to be DRC error free for the ULP to operate correctly?
It would be helpful to hear from somebody with definitive experience on this.
Best wishes
Ron
PS - Having resolved all DRC errors, the exception still occurs.
A bit stuck now. Can't think how to progress without gradually picking apart the board to try to get it to a state where the ULP works, which it did when the board was simpler.
    autodeskguest over 11 years ago in reply to ronsegal
    On 30/10/2014 06:27, Ron Segal wrote:
    Thanks Warren and for the heads-up on the newer ULP file. For some
    reason I hadn't found that one.
    Best wishes
    Ron
    http://www.element14.com/community/message/129912
    The most recent update I made is V6-6, here is the modification history:
    29 May 2013 - Fixed the Resolution settings to avoid generating short
    'mismatch' airwires.
    29 May 2013 - Added the ability to remove polygons before routing to
    avoid breaking their consistency and generating airwires.
    30 Sept 2013 - Fixed naming of the file that gets DRU values to work
    correctly on MacBook Pro
    30 Sept 2013 - Default disable drawing of of a potential huge amount of
    small component outline vectors
    30 Dec 2013 - Add default via in case of single layer to set scope for
    autorouter.
    14 Jan 2014 - Removed the cumbersome intermediate file to get design
    rules, use the XML in the BRD file instead (requires Eagle V6).
    26 Jan 2014 - Bug fix in reading dimensionless numbers from the BRD file.
    8 March 2014 - arc2line routine ignores microscopic curves
    13 April 2014 - Added missing via-via clearance.
    19 April 2014 - Corrected PAD size calculation for single layer routing
    on bottom layer, without a top layer
    ZIP file of the V6-6 ULP attached.
    Robert
    eagle2freerouter19-apr-2014.zip
  • ronsegal
    ronsegal over 11 years ago in reply to autodeskguest
    Thanks Warren and for the heads-up on the newer ULP file. For some reason I hadn't found that one.
    Best wishes
    Ron
    Good to see you found your issue
    Have you downloaded and tried
    eagle2freerouter-8-march-2014.zip
    It looks to be a little later than yours
    Warren
  • ronsegal
    Ok, answering my own question.
    After progressively ripping up hand routed tracks on the board and running the ULP, I discovered that it does not like some kinds overlaps where a track is joined to a part, even though these connections don't cause DRC errors.
    So the solution was to clean up all hand routed tracks where they attach to parts.   Now the DSN file successfully generates.
    Hope this helps somebody.
    Best wishes, Ron
