EAGLE User Chat (English) Quickly and easily remove all .s# and .b# files
  • Replies 8 replies
  • Subscribers 187 subscribers
  • Views 1433 views
If you're anything like me, you sometimes want to get rid of the .s# and
.b# files because you have completed something and don't need them
anymore or have an extensive backup system, or whatever. Here's a simple
batch file script I created with the help of a forgotten site that will
remove all of them from all directories. It's recursive, so I place the
batch file in my projects directory and run it on occasion.
Copy and paste this into a file named remove_s#_b#.bat:
FOR /F "tokens=*" %%G IN ('DIR /B /A-D /S .s#') DO del "%%G"
FOR /F "tokens=*" %%G IN ('DIR /B /A-D /S .b#') DO del "%%G"
Travis
    autodeskguest over 16 years ago in reply to autodeskguest
    Greg Erskine wrote on Thu, 10 December 2009 01:32
    I use bat or
    perl scripts to automate my tasks but that is not normal practice
    anymore.
    Most people prefer Window interfaces.
    That is only because most people don't have a clue about computers and are
    afraid of the command line because it looks too computer-ish.  We are on a
    technical forum here, specifically for people that know how to design
    circuits and can use a complicated program to help with that.  Don't judge
    everyone here by what the average idiot does.  Remeber that we are the
    people designing the stuff so that the average idiot can continue to be a
    idiot.
    One of the really nice and important features of Eagle is that it is
    essentially command based, with the clickety-click interface mostly layered
    on that.  That allows you to use the mouse for some interactions that are
    inherently graphical where a pointing device adds real value, but also
    allows scripting and encapsulating canned procedures.
    Quote:
    In some work environments you are not
    given access to CMD.exe
    I have never been exposed to that and wasn't aware of that, but as has
    already been pointed out anyone with enough smarts to run Eagle can
    trivially get around that.  It's really more of a intelligence test that
    anyone who is here should be able to pass, else they don't really belong
    here.
    "Christoph Wurzinger" <christoph.wurzinger@tugraz.at> wrote in message
    news:hfq7fa$1un$1@cheetah.cadsoft.de...
    Greg Erskine wrote:
    "Olin Lathrop" <eagle@embedinc.com> wrote in message In some work
    environments you are not given access to CMD.exe
    Maybe direct access (via Start->Programs->... or Start->Run) is disabled.
    However, the following line inside a .cmd-file always allowed me to use
    the command line interactively:
    cmd.exe /K
    Don't tell your sysadmins image
    Christoph
    Shhhh. I worked that one out many years ago. Don't tell anyone. image
    disabled. However, the following line inside a .cmd-file always allowed
    me to use the command line interactively:
    cmd.exe /K
    Christoph
    news:hfp2c4$lb1$1@cheetah.cadsoft.de...
    Greg Erskine wrote on Wed, 09 December 2009 01:00
    If you want to use windows to quickly do this then:
    I was talking about Windows, the command I mentioned is specifically for
    CMD.EXE, the standard Windows command line shell.  No penguins or red
    fruit
    were mentioned or implied in my message.
    Quote:
    open windows explorer
    right-click on the directory
    select search
    type .#*
    left-click in right pane
    ctrl A
    del
    I wouldn't call this "quick" compared to a single line command, but yes
    that should work too.  You can't script it, include it automatically in
    your back procedure, and you have to put up with all that
    clickety-clicking, but it would work.
    Thanks for the clarifaction but I understood what you meant. I use bat or
    perl scripts to automate my tasks but that is not normal practice anymore.
    Most people prefer Window interfaces. In some work environments you are not
    CMD.EXE, the standard Windows command line shell.  No penguins or red fruit
    select search
    type .#*
    ctrl A
    del
    "Travis G" <fightspammers@gmail.com> wrote in message
    news:hfk1fi$4ci$1@cheetah.cadsoft.de...
    I don't see the advantage over the simpler and more obvious:del .s#
    .b#
    /q /sI use the even simpler:del # /q /s
    It's only obvious if you know about it image
    I didn't realize that the del command had a recursive switch, and that
    method didn't come up in any of my google searches at the time...
    I learn something new all the time... Now if I can just remember it for
    next time image
    select search
    type .#*
    ctrl A
    del
    This can do all your projects if you select the directory high enough up the
    tree.
    I don't see the advantage over the simpler and more obvious:del .s# .b#
    next time image
    Travis G wrote on Wed, 11 November 2009 16:13
