EAGLE User Chat (English) Rust inhibitor circuit
  • Views 722 views
Hi
I was wondering, does anyone happen to know of any schematics for those rust
inhibitor circuits that prevent rust from forming on your vehicle?
it's JUST a little circuit that send current to little sacrificial anodes
you mount on your vehicle in certain places.
Glen
    autodeskguest over 16 years ago in reply to autodeskguest
    Interestingly enough,  they put a zinc strip down the bottom of caskets
    as well
    Morgan Leijström wrote:
    Cirquit?
    I guess it just limits current in case of overload/short cirquit, and a
    voltage regulator to make it have sufficient voltage but not ecessively
    to cause unecessary wear.
    So some adjustable or fixed voltage regulator and resistor to limit to
    one mA or such...
    But i doubt it works on vehicles, as the effect will be very local.
    On boats it is another deal, when the vehicle is in the "electrolytic"
    Common on boats is to use Zink slabs.
    On vehicles the method is to use zink plated steel - which is used
    nowadays.  There are also zink sprays you can use to repair or add this
    to old vehicle; first grind to bare metal, then spray the zink coating,
    then paint or protective layer.
    Much better and more reliable!
    Glen Higgs wrote:
    Thanks Bob! for the link.
    Anyone else have a schematic, for a rust Inhibitor circuit?
    "Bob" <Bob@invalid.invalid> wrote in message
    news:hdjuo8$tc2$1@cheetah.cadsoft.de...
    those rust inhibitor circuits that prevent rust from forming on your
    vehicle?
    anodes you mount on your vehicle in certain places.
    I have no schematic, but I'm afraid they don't work all that well anyway:
    http://www.alfabb.com/bb/forums/detailing/24172-rust-prevention-3.html#post266845
    Bob
    Cirquit?
    one mA or such...
    vehicle?
    Bob
    rust inhibitor circuits that prevent rust from forming on your vehicle?
    Bob
    Bob
