EAGLE User Chat (English) Windows recently opened documents
  • Subscribers 177 subscribers
  • Views 311 views
Does somebody know how I can make Eagle sch or brd files get displayed in
the windows XP "Recently Opened Documents" list that is displayed in the
start menu? I have an extreme lot of disorganization in my projects folder
(what shows up in the Eagle Control Panel) and sometimes have a hard time
finding and returning to the most recent version of a project I was working
on.
I know I could turn each design into a project and then OPEN the project -
but that is last resort because if there were more than one design that I
might want to work on alternately, then it would not help when going back
and forth.
I'd appreciate any pointers. Would I need to edit the registry, or is there
even a way?
    on.
    and forth.
    even a way?
    Right-click on a brd file, go to open with->choose program. Browse to
    the eagle.exe file in your program files directory. Check the Always use
    this program checkbox. Do the same for the sch file.
    If any of that is wrong, it's cause I can't remember exactly the
    phrasing xp uses and am on vista right now.
    "Travis G" <fightspammers@gmail.com> wrote in message
    news:he5dse$pjn$1@cheetah.cadsoft.de...
    folder
    working
    on.
    project -
    and forth.
    there
    even a way?
    Right-click on a brd file, go to open with->choose program. Browse to the
    eagle.exe file in your program files directory. Check the Always use this
    If any of that is wrong, it's cause I can't remember exactly the phrasing
    That answer was right on the money for the loading sch files.
    My right click menu did not have an "Open With" option as I tried to do the
    same for BRD files,
    so I made a file association with the same good result.
    Thanks, Travis.
    afaik, only documents that are opened from windows explorer appear in
    the recent doc's menu.
    but it would seem to me that projects are what you should be doing, at
    least on EAGLE 4 it seems to make it easy to CUT and PASTE between
    different designs, like one click easy... what exactly is the issue that
    makes projects undesirable?
