EAGLE User Chat (English) "Negative space" text
  • Views 605 views
I downloaded a Eagle board for a Single Sided Serial Arduino. When I
clicked the ratsnest button to calculate the polygon fills, there
appeared "negative space" text. the best way to describe it is that it
looked like the text vectors (and the space it would occupy) was
subtracted from the pour. How can I duplicate this for my projects?
Not trying to break any rules, but here is a link to a screen capture of
the result.
http://picasaweb.google.com/jay.couture/Circuit#5408119838448663954
Jay
    the result.
    Don't forget to watch for potential ground loops depending on where your
    text is located and what kind of currents and frequencies you have running
    around your board...  If you have the text (positive or negative) near an
    edge, it doesn't hurt to have it close enough to keep from pouring around
    all four sides of the text...
    cheers,
    ..dane
    of the result.
    Jay
    I got a reply on another forum that the designed used a proportional
    font on the bRestrict layer for this effect. Hope I'm not the only one
    that learned a new trick image
    It is best not to use proportional text for any for copper or silk
    layer. But thinking about it I see that in case of Restrict layer
    subtracted from a polygon it should be wysiwyg and be OK.
    Also to get tighter fills use a smaller polygon with the correct rank
    covering the text with zero clearance. You should have the width set to
    your board house DRC minimum.
    Paul R.
    the result.
    Jay
