EAGLE User Chat (English) Dealing with multiple boards?
  • Views 2268 views
Hi all. I've been using Eagle for a few years, but mainly for small, stand
alone boards. Now I'm working on a project that will require multiple small
boards that all interconnect. I'm thinking about upgrading to a version
that supports multiple schematic sheets so each board can have its own
schematic. What's the best way to deal with the multiple boards though?
Presumably when you create a design with multiple schematic sheets all of
those parts end up in the board file too right?
Thanks!
Josh
  • Morosh
    Morosh over 16 years ago
    "Josh" <joshybear@gmail.com> wrote in message
    news:hf0lo5$sm7$1@cheetah.cadsoft.de...
    small
    Thanks!
    Josh
    Have a look at "merging.zip" (download --> ulp), you can merge designs
    easily (both schematics and layouts).
    Maurice
    My approach depends on the project.
    You could do it all in one sch/brd pair, but you will always have
    airwires between all the common signals on the separate brds, which
    would drive me crazy so I do it in separate files.
    What I have done in the past is design a single schematic
    For ease of understanding the schematic, I had a project with 3 boards
    contained within a single schematic on 2 sheets.
    Then I laid out the two PCBs next to each other, having placed the
    connectors and mounting holes as required.
    I laid all three boards out next to each other: this made aligning
    mounting holes and connectors and any pin swapping very easy.  I also
    had the outline of the case so I could arrange the boards properly with
    respect to the heatsinks etc.
    This worked great except for one thing. The board house I use don't
    really like two separate boards in one set of Gerbers.
    Once I've completed the design (ignoring any airwires between boards) I
    copied the board file ONLY into my "Manufacturing" directory 3 times and
    renamed for each individual board.  Then I deleted the other boards to
    leave a single board per file.  I used common Drill & CAM files to
    create the manufacturing files for each board.  Works fine for me and
    enforces change control since the schematic is detached from each of the
    3 boards. YMMV.
    Cheers
    Neil
    On Mon, 30 Nov 2009, Travis G wrote to us saying :
    What I have done in the past is design a single schematic with the
    inter-board connectors shown, so that some net wires on the schematic
    have a plug-socket pair in the middle of them. This meant that I was
    explicitly NOT putting each board on a separate sheet - if you're doing
    that you may as well use a separate schematic. I had sheets with bits of
    each board, because the boards were stacked to make a single final
    assembly.
    really like two separate boards in one set of Gerbers. I thought I had
    agreed a suitable solution with them (using a milling pattern to
    separate the two halves after PCB production) but actually they ended up
    supplying the fully populated boards still joined together. Oh well, a
    few minutes with a hacksaw fixed that.
    These days I use a separate schematic for each board, but I might do the
    single schematic trick again if the boards are tight-coupled.
    Rob Pearce                       http://www.bdt-home.demon.co.uk
    The contents of this | Windows NT crashed.
    message are purely   | I am the Blue Screen of Death.
    my opinion. Don't    | No one hears your screams.
    believe a word.      |
    Josh wrote:
    Ah, that's what I was afraid of. I like to keep the schematics together to
    help me make sure I'm wiring connectors the same, etc. Not a huge deal, but
    it helps me to avoid stupid mistakes. What I've done in the past is to
    create a large schematic with all the parts on it, then cut and paste the
    remote board ones into a new schematic file. It's a bit messy as my main
    schematic then ends up with a bunch of unconnected things, but I could
    always delete them too if I was really worried about it.
    Thanks!
    Use good and constant net names between boards then if you export the
    net list by device the mating connectors from each export should be easy
    to check.
    Paul R.
    Thanks!
    Thanks!
    Josh
    Best thing to do is have separate sch/brd files for each board.
    If you do it all on the same brd, just surround each brd with lines on
    the dimension layer, and space them about 50mils apart so you can have
    the board house build them and tab route between the boards.
